intake mods
intake mods
what should I use to reshape the inside of the intake manifold. I had to machine some room for the SV 1 and need to build up and taper portions of it. \what prep if any is needed. is jb weld safe to use?
Larry Williams- Posts : 884
Re: intake mods
Vaspar or similar epoxy works. Jb is a little Generic for the application IMO
Re: intake mods
Larry Williams wrote:what should I use to reshape the inside of the intake manifold. I had to machine some room for the SV 1 and need to build up and taper portions of it. \what prep if any is needed. is jb weld safe to use?
Z-Spar, "splash zone" works real well.
Re: intake mods
rmcomprandy wrote:Larry Williams wrote:what should I use to reshape the inside of the intake manifold. I had to machine some room for the SV 1 and need to build up and taper portions of it. \what prep if any is needed. is jb weld safe to use?
great info thank you. I found a supplier only a few hours from me. I will order it Monday
