comp cam 34-443-9
comp cam 34-443-9
Anybody run this cam?, 242/ 248 @ 50 553/572 lsa 110, going in 545 p51 10.5-1cr fast 2.0 efi c6 78 f100 street warrior.
Last edited by outbackbbf on May 10th 2014, 8:20 pm; edited 1 time in total (Reason for editing : Didnt spec cam)
outbackbbf- Posts : 30
Re: comp cam 34-443-9
i think in the power range your achieving with that grind a solid flat tappet would be a better fit for a street warrior
jc10000rpm- Posts : 193
Ok thanks for ur reply
outbackbbf wrote:Anybody run this cam?, 242/ 248 @ 50 553/572 lsa 110, going in 545 p51 10.5-1cr fast 2.0 efi c6 78 f100 street warrior.
I used one in a customer's D0VE headed, "street" class mud drag racer.
It was not driven on the street though.
Thanks for ur reply . Do u recall how it performed in that application ?, manifold vacuum maybe? Thanks
» Open Comp - Pro Comp class NMRA
» COMP Cams 34-229-4 - COMP Cams Magnum Hydraulic Cam/Lifters
» Comp cam New in the box
» New 604" bullet for the truck
» Replacement Camshaft
