Fox swap
Fox swap
Building 85 fox with 532 A429 heads ported with a little nitrous . Was planning A headed combo but shortblock was already built so I will save it for the next combo. Have ran SBFwith C4 for years. And now time for a change.kasse solid roller specd out for A460 heads wondering how much it will hurt me on the smaller heads.Pictures to come when I get smart enough to figure out how!
BIGBLOCKBOE- Posts : 21
Re: Fox swap
I would not uses it just because it bigger does not mean it better.You will have to use photobucket to post pictures just load your pictures to bucket then copy/paste to this site.
bigjohn2007- BBF CONTRIBUTOR
Re: Fox swap
What's the cam specs?
Fox Swap
Could you tell us more about your Build,Cam specs,comp ratio,what did your A heads flow,are they stock ,are ported?Thnx,MavMan
1970 ford maverick- Posts : 180
532 cobra jet heads
Mav man the trick flow 340 cc heads 2.3 intake with cnc chambers , was going to run them like that but will be ported now. Cam 780 lift I think it is 286 duration on 112 . Nice Mav. Comp should be around 12 or 13 to 1 JE flat tops bore 4.440 victor in f2f ake and heads are ported
Fox Swap
Boe,im no pro,but I would run that cam . I think you will be very pleased with the performance,keep us posted!BIGBLOCKBOE wrote:Mav man the trick flow 340 cc heads 2.3 intake with cnc chambers , was going to run them like that but will be ported now. Cam 780 lift I think it is 286 duration on 112 . Nice Mav. Comp should be around 12 or 13 to 1 JE flat tops bore 4.440 victor in f2f ake and heads are ported
» Fox swap 460 oil pan
» Aod swap?????
» 460 to 429 C6 swap
» Need some help on a swap MEL to BBF
» 460 SWAP INTO MY 94 F150
» Aod swap?????
