460 race parts
460 race parts
I need some parts for my 460 ASAP, and I'm getting them wether they are used or new. I want this engine together right away. I need:
Harmonic balancer
164 tooth flexplate
6.605 connecting rods (I'll probably buy these new)
Single plane dominator flange intake of some sort
Cam and lifters, possibly springs. I need a solid flat tappet or mainly a solid roller.
Possibly windage tray and/or front sump oil pan
This is a high compression 110/E85 setup, I pulled the engine and I'm replacing bearings but I want to make it go faster while its out. Already a very healthy engine, in a 3450 pound fairlane.
Message me or post here with anything you may have. I'm itching to order everything, I want as minimal down time as possible. I'd like to have enough power to pull the wheels in all reality, I'd like a 10 second car
Harmonic balancer
164 tooth flexplate
bb429power- Posts : 3129
Re: 460 race parts
Justin, what pistons are you going to be using? Do they require full floating pins or pressed? I have a set of eagle SIR rods if your using factory style pistons that don't use spiral locks... Might have a solid flat tappet cam/lifters from comp cams and also possibly a used solid roller cam/lifters if you choose to go that route... If your interested in any of this stuff let me know... I might have some of the other stuff also if I do some digging...
bluef100fe- Posts : 379
