Bottom water pump bolts?
bigjohn2007
Bottom water pump bolts? Empty Bottom water pump bolts?
Post  bigjohn2007 May 21st 2014, 10:19 pm
I was installing front motor plate and when i got to the bottom 2 bolts one stripped.Are these bolts threaded in the block or just in the timimg cover?I can see few of top one are threaded to block but cant see if two bottom one is.
bigjohn2007
bigjohn2007
Bottom water pump bolts? Empty Re: Bottom water pump bolts?
Post  rmcomprandy May 21st 2014, 10:20 pm
bigjohn2007 wrote:I was installing front motor plate and when i got to the bottom 2 bolts one stripped.Are these bolts threaded in the block or just in the timimg cover?I can see few of top one are threaded to block but cant see if two bottom one is.
The bottom bolts are just in the cover however, one of them is a through hole.
Post  bigjohn2007 May 21st 2014, 11:38 pm
Is it the bottom (Right One)?This is not one of the holes you would use with electric water pump it on bottom of the back plate.Any tips on how you guys have fixed or made better after stripping the small 5/16 bolts when installing motor plate.thanks
bigjohn2007
bigjohn2007
Post  Gregaust May 22nd 2014, 5:39 am
Helicoils are the fix .
Gregaust
Post  powerstrokeace May 22nd 2014, 12:32 pm
JUST REMEMBER THE SHAVINGS WILL FALL IN TO THE OIL PAN
ACE
powerstrokeace
powerstrokeace
Post  Frank Merkl May 22nd 2014, 7:37 pm
the hole is the open hole . pull the timing cover and put a helicoil in it . don't do it with the cover on as you get filing in the motor and the install tit for the helicoil when you break it off to finish the install will undoubtedly will fall on the timing gear and lock and break the chain an the first fire up!
Post  nuclearcobra May 22nd 2014, 8:17 pm
Studs
nuclearcobra
nuclearcobra
Post  bigjohn2007 May 23rd 2014, 2:40 am
Well,went got a 3/8 tap with 2 new bolts grade 8.Oil the tap up with a little Blaster and begin gentle and easy lol.I marked the tap with yellow marker 1 inch then screwed it in back and forth blowing the shaving out with air compressor.Then install 3/8 bolts and all looks good with no leaks.Put all together and fired up everything look@sounds great.
bigjohn2007
bigjohn2007
