be on the look out.
56Tbird
460bronco
dave d
blown86hallet
be on the look out.
Boat is still in the MOCK up stage..
Pretty parts will be going on this weekend..
Just a couple of more little parts or adaptors left to do....
time to turn and burn some ALKY!
Stickers by "DAN-O". Gold leaf, bad ass!
blown86hallet- Posts : 1012
Re: be on the look out.
Wow! That thing is a beast! What kind of times do you think it's going to run?
460bronco- Posts : 364
460bronco wrote:Wow! That thing is a beast! What kind of times do you think it's going to run?
its not a drag boat. its a circle boat.
https://www.youtube.com/watch?v=lkxtExf9ZQc
Looks BadAss Adam!!! Can't wait to see Big D after you take him out in that beast!!
56Tbird- BBF CONTRIBUTOR
56Tbird wrote:Looks BadAss Adam!!! Can't wait to see Big D after you take him out in that beast!!
Be sure that Big D is wearing all of his Black Bass Fishing gear and the sun is bright LOL!
D. Sea- Posts : 2768
not sure "D" will even get in this one?
Maybe ill get him drunk and say were going fishing?
he'd get his rod hung in the blower belt
...but could likely do mid 7's in the quarter, if not quicker.blown86hallet wrote:460bronco wrote:...What kind of times do you think it's going to run?
56Tbird wrote:he'd get his rod hung in the blower belt
LMFAO!!! Now that's F-ing FUNNY!!!!
Big D... Are your ears burning? We are talking about you. You need to defend yourself
Paul Kane wrote:...but could likely do mid 7's in the quarter, if not quicker.blown86hallet wrote:460bronco wrote:...What kind of times do you think it's going to run?
Paul
I'm not trying to avoid ya, I removed my larger mag and installed my sprint mag, seems like it might clear the blower belt?
If it doesn't ill be ordering one of your off-set drives...
Hey whatever works. Fact is I was wanting to talk only because I was going to suggest first trying smaller pulleys top and bottom (which would keep pulley ratio the same/similar).blown86hallet wrote:Paul
Paul Kane wrote:Hey whatever works. Fact is I was wanting to talk only because I was going to suggest first trying smaller pulleys top and bottom (which would keep pulley ratio the same/similar).blown86hallet wrote:Paul
I have to run the size I have.
I'm running a U-joint off my damper to my drive line, with that said I needed 4 1/2" min ID on my smallest pulley.
Ill post pics of my adaptor and U-joint
Man and I thought I was nutz that is some straight up crazy stuff there , I'd love to see the look on my neighbors face if I had that tied up to my pier
nuclearcobra- BBF CONTRIBUTOR
BBC snout.
Billet Bryant crank
Billet Bryant crank
Whew, good.
What's the angle of the v-drive and is u-joint mandatory? Are you running a balancer or a blower hub so that the pulley could be flipped around?
The v-drive is a 10deg
The Angle will between 2 - 5 deg. Fingers crossed
But the snout and v-drive plane will be dead flat ( like a solid drive line circle boat )
I'm getting my deg from the installation of engine more on the drivers side.
Putting the engine more on the inside ( sort of speak.) like dirt tracking.
I don't have the exact measurements for how far to the left the engine will be from center. I'm still setting the placement of the engine length from the rear of the boat. Looking between 35" to 33 1/2".
Once I get my placement from the rear ill figure how far to the left I can go keeping my u-joint deg happy.
I'm running a damper.
Here's a BBC-snouted setup with PTO for a build I was doing for a Super Stock style circle boat with a 429 steel truck crank:
I understand now that you relocated your engine for LTO, thought maybe you wouldn't necessarily need a U-joint up against the balancer.
Lance Faulkner use to set his engines in on the left with no u-joint.
After lance passed away and Ty newton took over the drivers seat Ty and his dad jim started looking for a "super bad vibration". Well engine to the left solid drive line, not a happy boat
Dave rankin is running a u-joint, off the v-drive thou.
I'm not saying my attempt at this is gonna work?
But you will never know unless you try. Fingers crossed.
Sucks you guys couldn't get that ford in the field.
Then they go and change the rules " chevies only!"
what about fabing up a cv shaft of some kind....
torino501- Posts : 417
