Oil pan help
Oil pan help Empty Oil pan help
Post  tfsbbf466 May 23rd 2014, 11:21 am
I need a new oil pan for my truck. It takes a fox style rear sump pan. Current one seems to leak from everywhere no idea why. What should I buy that people have had good experience with? 4.15 stroke 514 stock 2 bolt block street strip been 9.98 130. Hoping for solid high 9s after a few small changes.
tfsbbf466
Oil pan help Empty Re: Oil pan help
Post  dfree383 May 23rd 2014, 11:34 am
Canton, Moroso, Milodon all make shelf pans that's are good
Post  tfsbbf466 May 23rd 2014, 2:35 pm
I have a Moroso with a brand new 1 piece gasket and it seems to leak from everywhere.
tfsbbf466
Post  dfree383 May 23rd 2014, 2:37 pm
Did you install, seal and torque everything properly?
Post  tfsbbf466 May 23rd 2014, 10:11 pm
I used a FMS 1 piece gasket and I tighten from the middle of the block outward on both sides. Not torqued just tight with a 1/4" ratchet. None of my other motors leak with stock pans bbfs and Windsors. I did change a cam in the truck though I don't remember if it leaked beforehand. Either way I want a new pan when I pull it out.
tfsbbf466
Post  tfsbbf466 May 25th 2014, 12:33 pm
Ok trans took a dump so motor is coming out. I want a new pan either way which should I buy? Mine may be ok but I would rather not take a chance.
tfsbbf466
Post  jeffgfg May 25th 2014, 4:47 pm
If you changed the cam while it was still in the truck i would bet that the pan is leaking where the front cover/ oil pan come together. It is tough to keep that from leaking if you aren't careful putting it back together. I would think that with the engine out and put together carefully you won't have any leaks. Plenty of these pans/gaskets out there with no leaks. Good luck!
jeffgfg
