Tach problems
Tach problems Empty Tach problems
Post  pigs521bbf May 27th 2014, 9:40 am
I have a sunpro tach, when the engine is running, the tach needle keeps going up and down. Not sure why.. I have Mallory ignition box and ignition panel with push start.. Any thoughts?
pigs521bbf
Tach problems Empty Re: Tach problems
Post  69F100 May 27th 2014, 10:07 am
My old Mallory Tach in my 69 it was loosing ground and the needle was jumping around would not do it until I got over 2000 rpm  I started checking all the connections when I found my problem check all your connections if everything good it more than likely the tach.
