best ratchet style shifter for a c6
best ratchet style shifter for a c6 Empty best ratchet style shifter for a c6
Post  bottomland4x4 November 10th 2009, 12:05 am
i have a c6 that is full manual valve body with a b and m megashifter thats just junk. what are you all running? i am also thinking of going to an electric solenoid to do the shifting for me later on. any recommendations? i want to hook the solenoid up to the shift light and make it like an automatic again, any ideas? i also have a c6 reverse manual built by frank merkyl with a transbrake that i may use. what are some of you guys running?
this is currently in a fox drag car but will make its way over to my mud race truck in my avatar. Very Happy
bottomland4x4
bottomland4x4
best ratchet style shifter for a c6 Empty Re: best ratchet style shifter for a c6
Post  lghting94 November 10th 2009, 1:22 pm
I run the cheetah turba action shifter and really like it I also have the dedenbear air shift system hooked up to it in my mud truck.
lghting94
lghting94
Post  aftershock November 12th 2009, 11:02 pm
x2 with the cheetah shifter with the air shifter thats what i am running. Stay away from the electric shifts I know a guy that has one now that shifts half the time and in a rough mud hole the lever jumps off of the shifter.
aftershock
Post  bottomland4x4 November 13th 2009, 10:59 am
i am just not real crazy about having to fill the co2 tanks for the air shifter. about how many shifts do you get with the c02 shifters? i figured the electric would be the way to go?
bottomland4x4
bottomland4x4
Post  lghting94 November 13th 2009, 11:58 am
I race 20-30 races a year two passes at each race plus all the test passes across the yard and can generally get almost two full years out of a 10 oz bottle and the paintball guy refills it for 2 bucks
lghting94
lghting94
Post  bottomland4x4 November 13th 2009, 12:13 pm
well thats not as bad as i first thought! it seems that its a lot cheaper than the electric solenoid also.
bottomland4x4
bottomland4x4
Post  aftershock November 15th 2009, 2:54 pm
I have had mine for 3 years and filled it once.
aftershock
Post  67460 November 16th 2009, 11:18 pm
I use Precision KWIK–SHIFT II , havn't use my Co2 yet but I have it, my trans is the same set up as yours and I like it.
67460
67460
