quick fuel msd 9 inch sold sold sold
new 1050 quick fuel carb 500.00 plus shipping
new msd 429/460 dist 175.00 plus shipping
9 inch ford 31 spline posi with new clutches 150.00
shipping from 72801 Russellville Ar.
everything has been sold thanks,
Steve
Steve
70429scj- Posts : 348
MSD Dist
PM sent on distributor
Rich Osmond- Posts : 217
Re: quick fuel msd 9 inch sold sold sold
You have pm
res0rli9- BBF CONTRIBUTOR
Whats the model # of the carb?
Tore- Posts : 865
Well theres 4 models list as Q. There should be a part# like an RQ____
Thanks Tore
Thanks Tore
Tore- Posts : 865
carb
Tore listed on summit as q-1050 listed on quick fuels site as q-1050. this is the base model in the drag series
Brand:Quick Fuel
Manufacturer's Part Number:Q-1050
Part Type:Carburetors
Product Line:Quick Fuel Q-Series 4-Barrel Carburetors
Summit Racing Part Number:QFT-Q-1050
CFM:1,050
Fuel:Gasoline
New or Remanufactured:New
Number of Barrels:4
Carburetor Flange:Square bore
Choke:None
Secondary Type:Mechanical
Fuel Inlet:Dual
Primary Jet Size:86
Primary Power Valve (Hg):4.5 Hg
Secondary Jet Size:93
Primary Outer Air Bleed Sizes Included:70
Primary Inner Air Bleed Sizes Included:28
Secondary Power Valve:Plug
Secondary Outer Air Bleed Sizes Included:70
Secondary Inner Air Bleed Sizes Included:28
Carburetor Finish:Tumble polished
Ford Kickdown:No
Booster Type:Down-leg
Throttle Linkage Type:Universal
Quantity:Sold individually.
Notes:Carburetor features the Proform high-flow main body, billet metering blocks, and billet throttle baseplate. Fuel inlets are 7/8-20 in. thread.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
CalculatorCFM Calculator
Get big-time performance with Quick Fuel Q-Series 4-barrel carburetors with Proform high-flow main bodies, which include either down-leg or annular boosters, screw-in idle and high-speed air bleeds, accelerator pump discharge nozzles, and a blended venturi area. These carburetors have CNC-machined billet metering blocks with 4-stage emulsion to provide more precise fuel metering, improve throttle response, and give a more uniform fuel performance curve. With so many great benefits and their blend of performance and drivability, it's no wonder that these Quick Fuel Q-Series carburetors are the popular choice. So, go ahead--throttle it up with Quick Fuel!
Warranty
Brand:Quick Fuel
CFM:1,050
Fuel:Gasoline
Number of Barrels:4
Choke:None
Fuel Inlet:Dual
Primary Jet Size:86
Ford Kickdown:No
Warranty
» Quick Fuel Carb 4150 base 1050 cfm SOLD SOLD SOLD
» Quick fuel 950 SOLD!
» Quick Fuel 1250 F/S SOLD!!!
» QFX1050 QUICK FUEL ////SOLD
» Quick Fuel 1150 "SOLD"
