1958 Ford Fairlane 500... 429? will it fit?
466cj
Wheelie58
JohnnyBGood
1958 Ford Fairlane 500... 429? will it fit? Empty 1958 Ford Fairlane 500... 429? will it fit?
Post  JohnnyBGood June 2nd 2014, 12:02 am
I have a 1958 Fairlane 500 Interceptor (352 4v). The engine is rusted and wont turn over; the carb is corroded beyond repair. I have an opportunity to buy a 1972 429 (rumored to be a Police Interceptor) and was wondering if it would easily fit and if someone sells motor mounts and such for the conversion. Otherwise I would make my own mounts without a problem since I have a machine shop. If not a 429 then perhaps a 4.6 (police interceptor) or 5.4 EFI unit. Any help/advice/experience on the 429/'58 Fairlane question would be greatly appreciated. Thanks in advance.
JohnnyBGood
1958 Ford Fairlane 500... 429? will it fit? Empty Re: 1958 Ford Fairlane 500... 429? will it fit?
Post  bbf-falcon June 2nd 2014, 5:38 am
It's actually a great engine choice for the 58.A C6 tranny for a 351/400M or 429/460 will mount right in, and your stock 429/460 exh. manifolds may be the right ones also. As far as engine mounts,i'm not sure which ones you might need,but i'm sure someone on here can lead you in the right direction on the mounts. Very Happy
Post  69F100 June 2nd 2014, 11:25 pm
Keith see this he can more than likely get set in the right direction he got 58 custom
Post  Wheelie58 June 2nd 2014, 11:37 pm
Unfortunately, back in 73 when I got my 58..I had a 427 with factory rubber side engine mounts. When I swapped to a 460, I made some simple solid mounts from rectangular tubing. It will be simple to fabricate some plates to adapt a rubber 460 passenger car mount to the 58 frame.
Oh...just thought...I have a buddy that did the swap for street...I will ask him.
C-6 bolts right on to the trans crossmember.
Not sure about manifolds, but I think there is no problem.
You are about to experience one of the finest automobiles ever produced.
Smooth, comfortable and chicks will not leave you alone if you drive one.
Call any time to talk 58s.
Keith
678-458-2033
Wheelie58
Wheelie58
Post  466cj June 3rd 2014, 12:04 am
Crites sells mounts, crossmember, and headers to put a 460 in a '58 Fairlane as well as some other neat stuff.
http://www.tiptopwebsite.com/websites/index2.php?username=colson43&page=6
Only down side is sometimes can take awhile to get your stuff.
466cj
Post  JohnnyBGood June 3rd 2014, 11:18 am
Thanks for all the info guys. I think I am going to make a go of it. You Only Live Once! If it is a Police Interceptor I will leave it as is. If it is not then I will likely turbo charge it. It will be a classy Rat Rod for quite some time as it evolves. I believe in daily (or at least weekly) drivers. Rust in the usual places, but that's what I work on anyways so no biggie. Thanks again.
JohnnyBGood
Post  bbf-falcon June 3rd 2014, 11:51 am
Keep us posted. 57/58 Fords are Cool. Cool
Post  jasonf June 3rd 2014, 7:45 pm
I ordered the swap kit for my 56 from Crites and they build as you order so expect to wait 4-6 weeks. Not a big deal to me but some people expect 24 hour service.
I imagine it will be something similar to this.
1958 Ford Fairlane 500... 429? will it fit? Crites460swap
Post  jasonf June 3rd 2014, 7:54 pm
Ford Power Train also has headers available but hey are only 1 3/4". They are goofy looking to me but I guess it depends on your motor and expectations.
http://www.fordpowertrain.com/FPAindex/Fordpassenger1.htm
The pics below were for a 56. You can call or email them and they probably have some pics they can  send you.
1958 Ford Fairlane 500... 429? will it fit? Picture391
1958 Ford Fairlane 500... 429? will it fit? Picture390
I believe the FPA headers also work with Wurthits rack and pinion swap if that is in your future.
http://www.wurthitdesigns.com/
http://www.wurthitdesigns.com/57Ford.html
Post  58 Ford June 3rd 2014, 9:09 pm
If you don't go the header route manifolds from a 77 F150 clear everything and you can use the F150 y pipe to construct the exhaust. A little tricky fabing it up to clear the pitman arm travel but works good.
58 Ford
58 Ford
Post  bbf-falcon June 3rd 2014, 9:18 pm
58 Ford wrote:If you don't go the header route manifolds from a 77 F150 clear everything and you can use the F150 y pipe to construct the exhaust. A little tricky fabing it up to clear the pitman arm travel but works good.
I like your 58  Cool
Post  58 Ford June 3rd 2014, 9:34 pm
Thanks, its one I sold a few years back and now looking for a replacement to build.
58 Ford
58 Ford
Post  5pointslow June 4th 2014, 5:57 am
Wheelie58 wrote:Unfortunately, back in 73 when I got my 58..I had a 427 with factory rubber side engine mounts. When I swapped to a 460, I made some simple solid mounts from rectangular tubing. It will be simple to fabricate some plates to adapt a rubber 460 passenger car mount to the 58 frame.
Keith
678-458-2033
All i can say is when i met Keith up at New england dragway at the hot rod reunion , after talking to him with my old man about his car . I really didnt know much about the 58 due to not seeing them at all drags, or street cars atleast in my neck of the woods . Keith knows his stuff and im sure knows the car inside and out i wouldnt hesitate to call him and chat about your project .
5pointslow
5pointslow
Post  JohnnyBGood June 4th 2014, 11:38 am
Now I'm charged up about getting it going this fall. Time to start planning. I will be posting throughout the process and getting more insights. Thanks all!
JohnnyBGood
Post  JohnnyBGood June 4th 2014, 7:12 pm
So. I went to look at the 429 today and got some pictures. I am a little baffled in trying to decipher what I may have. I haven't purchased the engine yet but I am still trying to determine what I am getting into. He said that his brother got it right out of a 1972 police car (perhaps not an interceptor police car...?)
The rear bores are ever-so-slightly larger than the front.
I cannot send the photos. Too big. the carb has no markings at all. The rear two ports are ever-so-slightly larger than the front. I have never seen one like it has neither has the owner. The casting right above the exhaust port says D2VEAA. Can anyone help with what this would actually be?
If you want photos I can email them. Thanks.
JohnnyBGood
Post  514F-1 June 4th 2014, 8:51 pm
They fit great, my dad just bought, and I mean just bought, he picked it up just the other day, a '56 Victoria Street rod, he was told it had a 428 FE, but once we looked at it, it actually has a 460, much better IMO. Smile It fits like it was made to be in there.
514F-1
514F-1
Post  466cj June 5th 2014, 12:03 am
JohnnyBGood wrote:So. I went to look at the 429 today and got some pictures. I am a little baffled in trying to decipher what I may have. I haven't purchased the engine yet but I am still trying to determine what I am getting into. He said that his brother got it right out of a 1972 police car (perhaps not an interceptor police car...?)
Not a PI engine. Is just a run of the mill 1972 429 or 460 (if it was in a Lincoln). The D2VE heads give it away. Those are the only open chamber BBF heads and used for one year only, 1972 as they are detonation prone.
466cj
