efi intake conversion
efi intake conversion Empty efi intake conversion
Post  jasonf June 4th 2014, 2:21 pm
Where is a good place to have an intake converted to efi and fuel rails machined?
efi intake conversion Empty Re: efi intake conversion
Post  dfree383 June 4th 2014, 2:44 pm
Edelbrock makes a kit
http://www.edelbrock.com/automotive/mc/manifolds/ford/victor-bb.shtml
Post  jasonf June 4th 2014, 2:52 pm
dfree383 wrote:Edelbrock makes a kit
That is a torquer manifold for standard port heads. I see pro comp makes on now but I can't bring myself to buying one of those. I'm looking to convert my BT or vic jr intake.
Post  dfree383 June 4th 2014, 2:55 pm
The torker will for Scj ports.
And eddy has the rails if you want to use them on another intake.
Post  jasonf June 4th 2014, 3:15 pm
dfree383 wrote:The torker will for Scj ports.
I have the eddy rails but they are offset about 1/8" compared to the cj port. Below is a vic jr intake with the eddy rail you are talking about.
efi intake conversion A2D4AA9B-orig_zps2ec9c9c9
Post  rmcomprandy June 4th 2014, 3:51 pm
Wilson Manifolds - www.wilsonmanifolds.com/
Post  whatbumper June 4th 2014, 5:56 pm
we do those. I know we cant get to it for a few weeks though if you are in a hurry.
Post  SandHillsHillbilly June 4th 2014, 8:29 pm
This guy specializes in doing them.
http://www.hotrodsolutions.net/index.html
SandHillsHillbilly
SandHillsHillbilly
Post  Mustang-junky June 4th 2014, 9:19 pm
You could use these;
http://www.diyautotune.com/catalog/weldin-injector-bung-for-ev1-and-ev6-injectors-p-505.html
and not even need a fuel rail.
Jess
Mustang-junky
Mustang-junky
Post  fordguy69 June 4th 2014, 9:34 pm
Induction Solutions in Brooksville, Florida.
fordguy69
Post  whatbumper June 4th 2014, 11:01 pm
Mustang-junky wrote:You could use these;
Jess
Fuel rail would be the better option due to the fuel log aspect of it.
Post  SandHillsHillbilly June 5th 2014, 12:55 am
Jess
That would be a plumbing nightmare for 8 injectors. Might be ok for them 4 cylinder guys.
SandHillsHillbilly
SandHillsHillbilly
Post  Mustang-junky June 5th 2014, 8:59 pm
Jess
Mechanical fuel injection set-ups use a hose to each cylinder, right? I don't see why this would be much different pluming wise.
The problem I would see is that the fuel volume would be less than what a fuel rail would hold. But, a 6 -an to 1/4? NPT fitting would flow a good amount of fuel given it would be only for one cylinder.
Jess
Mustang-junky
Mustang-junky
Post  jasonf June 7th 2014, 9:22 pm
[quote="Mustang-junky"][quote="SandHillsHillbilly"]
Jess
Mechanical injection is constant flow where as an electronic injector is opening and closing which creates pulses in the fuel line. The volume in the fuel rail helps smooth out those pulses like a buffer so to speak. Or so I read.  Wink
Post  whatbumper June 7th 2014, 10:30 pm
Jess
Couldn't have said it better. Cool
