Installing quarter turn fasteners
Installing quarter turn fasteners Empty Installing quarter turn fasteners
Post  HorsinAround June 6th 2014, 11:03 am
Getting ready to install quarter turn fasteners on my fiberglass hood. From pictures I've seen, it looks like a lot of you make the mounting brackets out of rod, then weld the quarter turn plates to the rod. What size steel rod is normally used? I bought a Jegs kit that has 90 deg tabs which will work for the sides and rear of the hood, but gotta come up with something different for the front edge of the hood.
Also, if any pictures could be posted up so I can get ideas, I'd sure appreciate it.
http://www.frontpagefab.com
Installing quarter turn fasteners Empty Re: Installing quarter turn fasteners
Post  DILLIGASDAVE June 8th 2014, 1:12 am
Depending on who you talk to, & the weight of the fiberglass panel, & the amount of air it will be pushing, (like the leading edge of a hood vs the trailing edge of a front fender) Dzus tabs are usually welded to 1/4, 3/8, or 1/2 OD tubing. The tubing wall thickness is usually either .049, .058, or .065 wall. And both 'moly tubing & m/s tubing can be used in this application.
Post  HorsinAround October 29th 2014, 4:30 pm
what size/type of screw do you use to mount the faster to the hood itself?
Post  cool40 October 29th 2014, 7:55 pm
HorsinAround wrote:what size/type of screw do you use to mount the faster to the hood itself?
1/8" rivet.
Post  69F100 October 30th 2014, 12:24 am
1/8" rivet.
use stainless steel the aluminum ones don't hold up to vibration good and the steel ones will rust after awhile
Post  HorsinAround October 30th 2014, 9:29 am
Thanks guys. I'll pick up some stainless rivets, and get the holes drilled through the hood, then after paint, I'll get them installed.
Post  jeffgfg October 30th 2014, 10:07 am
There is a thread on the "other" site that is about this same issue. They even have pictures of installed tabs for the front edge. Good luck.
jeffgfg
Post  HorsinAround October 30th 2014, 11:47 am
Thanks, I rarely visit the "other" site. Found the info. http://www.460ford.com/forum/showthread.php?t=198473
Post  psfracer November 1st 2014, 3:37 pm
I have rails for mine for the hood that runs along the side, and then the "brackets" for the deck lid and for the front of the hood.  You can see them here next to the blue tape on the fenders.  I added two brackets off of the radiator (not pictured) after I mounted the rails first. Then I drilled holes in the hood, used smaller drill bit first so if I was a little off I could still adjust.  Measured twice also before each hole.....
Installing quarter turn fasteners IntakeNitrous9
Installing quarter turn fasteners IMG_0806
Then the typical brackets for the decklid:
Installing quarter turn fasteners Dzusfasteners4
Installing quarter turn fasteners Dzusfasteners6
Installing quarter turn fasteners CarbonFiberDecklidseams2
psfracer
psfracer
http://www.psfracer.com
Post  HorsinAround November 2nd 2014, 11:15 pm
It looks like you used screws to secure the fastener to the hood and trunk lid? Were they machine screws or sheet metal type screws?
Post  DILLIGASDAVE November 5th 2014, 2:15 am
IMO if you're using pop rivets (instead of the solid smash/hammer type "Dzus button rivets") to attach the Dzus button, the best pop rivet material to use really depends on the application & the material being riveted to. At first glance the stronger steel and/or Stainless steel pop rivets might sound like a better idea than the weaker aluminum pop rivets.
But depending on the situation it's sometimes better to use the softer aluminum rivet & allow it to fail over time from vibration/abuse (& have to replace the rivets over & over) vs using a stronger rivet & risking the increased chance of fiberglass, aluminum, or carbon panel damage.
Post  psfracer November 7th 2014, 2:15 pm
Into the body (for the rails and brackets) sheet metal screws. For the dzus fasteners to the carbon fiber hood/decklid, machine screws. I didn't want to use rivets into carbon fiber. On the decklid picture you can see I did use rivets for the rear wing, but that rear wing is aluminum.
psfracer
psfracer
