what spark plug on alum scj
gecsr
johndickjr
what spark plug on alum scj  Empty what spark plug on alum scj
Post  johndickjr June 9th 2014, 9:35 pm
what is a good spark plug to run on a naturally aspirated 472 with 12-1 compression, using alum scj heads
johndickjr
what spark plug on alum scj  Empty Re: what spark plug on alum scj
Post  rmcomprandy June 9th 2014, 10:08 pm
johndickjr wrote:what is a good spark plug to run on a naturally aspirated 472 with 12-1 compression, using alum scj heads
Does this have a domed piston or a flat-top...?
What brand would you like...?
Post  johndickjr June 9th 2014, 10:31 pm
Does this have a domed piston or a flat-top...?f
Flat tops .ive had good luck using autolite
johndickjr
Post  rmcomprandy June 9th 2014, 11:34 pm
Flat-top, 12/1, SCJ heads, NA ... I would use #3911 Autolites.
Post  Lem Evans June 10th 2014, 10:26 am
R5671A-8 if you are a NGK guy.
what spark plug on alum scj  Empty Spark Plug question....cont.
Post  gecsr June 11th 2014, 3:29 pm
So, would this 3911 hold true for the A-429 CJ head as well with the same conditions?
FT, ~12.0-1 CR, NA
Thanks,
Greg
gecsr
Post  quick 52 June 11th 2014, 4:36 pm
AR3934 there $4.00 or 3922, 3923 $2.00 .. myself I run the Ar3934 work with spray or n/a been in a couple years and still running fine
quick 52
Post  69F100 June 11th 2014, 11:39 pm
gecsr wrote:So, would this 3911 hold true for the A-429 CJ head as well with the same conditions?
FT, ~12.0-1 CR, NA
Thanks,
Greg
I am running the 3911 in my a 429 heads on my 552 with 14.7 c/r on alky and works good for me.
Post  crittersf1 June 12th 2014, 7:19 am
I'm with Lem on this one. Partial to NGK's.
crittersf1
crittersf1
Post  nuclearcobra June 14th 2014, 11:37 am
I have a 472 with scj's and diamond flat tops and use the ar3934's as Lem suggested , seem fine and last a while and worked good with a 125 shot so far.
nuclearcobra
nuclearcobra
