Hydroboost brake systems
I just recently put a set of SCJ heads on my motor in my 78 bronco... For whatever reason, my stock valve covers won't fit over my rockers any more. That's all ok because I had a set of tall ford racing aluminum valve covers to throw on the mill. ---- now, I have about an 1/8" clearance between my valve cover and brake booster. I have to unbolt the booster to take the valve cover off to adjust valve lash now.
My brakes aren't the best w/ the current cam combo due to lower idle vacuum.
Question is--- has anyone done a hydroboost setup on one of these 78/79 trucks/ bronco? I found several kits online, but was wondering if there was a different way of doing this or if there was an easy swap out there somewhere?
Thanks,
Jon
Thanks,
Jon
460bronco- Posts : 364
Re: Hydroboost brake systems
http://m.ford-trucks.com/forums/showthread.php?t=872090
68formalGT- Posts : 865
Manual Brake master cylinder for a 75 f-250(disc/drum option) is what I use to run as I didn't have enough vacuum for power brakes. It actually stopped better with manual brakes than the factory power.
lghting94- Posts : 762
lghting94 wrote:Manual Brake master cylinder for a 75 f-250(disc/drum option) is what I use to run as I didn't have enough vacuum for power brakes. It actually stopped better with manual brakes than the factory power.
4 wheel disc? Did you do anything with the proportioning valve?
Mine (a 79 bronco) I moved the stock booster over an inch or so and angled it toward the fender. It worked but was a fair amount of work.
The smaller f350 (I believe) booster provides a ton more room if you don't want to go hydro boost.
norm- Posts : 261
My truck was disc/drum factory distribution valve. Another modification I made later was to cross drill the front rotors and that helped alot by keeping pads cleaner. The f250 master has a bigger plunger(may not ne proper name) and sends more fluid to the drums and calipers. Just make sure the new master comes with the rod to hook to the brake pedal.
» Trans Brake vs Foot Brake
» 1250 Pro System Carb
» Pro systems SV1
» Pro Systems SV1
» pro systems carb
» Pro systems SV1
» Pro Systems SV1
» pro systems carb
