12" deck height iron block
12" deck height iron block Empty 12" deck height iron block
Post  jones June 20th 2014, 2:11 pm
I've been gone for a while and was interested in knowing if anyone on here has built one of these 12" deck heigth CGI blocks? What was the max bore on these engine?
jones
12" deck height iron block Empty Re: 12" deck height iron block
Post  jones June 20th 2014, 2:15 pm
I know some of you might actually wonder where I have been!! First off I finally found a job as a Surveyor so that leads to no computer time. Then I was rear ended and that ruptured a disc in my back. So it's all been nothing but joy.
jones
Post  schmitty June 20th 2014, 2:53 pm
Glad to have you back Josh.  How is the back doing?
Post  jones June 20th 2014, 5:44 pm
Well,,, I'm a month out of surgery, I'm a lot better than before the surgery!
I was just wondering if anyone has built one of these engines yet, I figure it would be in a truck puller if they had.
jones
Post  dfree383 June 20th 2014, 5:56 pm
Haven't heard of any, not sure the blocks have truly been produced.
Post  schmitty June 20th 2014, 6:06 pm
I doubt the pullers would use them.  They are usually ci limited.  Drag cars would be the most likely user
Post  dfree383 June 20th 2014, 6:14 pm
schmitty wrote:I doubt the pullers would use them.  They are usually ci limited.  Drag cars would be the most likely user
Too heavy......
Post  schmitty June 20th 2014, 6:17 pm
Too heavy......
Really?  How much heavier than an Eliminator or A block?
Post  jones June 20th 2014, 6:25 pm
I remember when they were first out for purchase and all the drag racers felt like they would be to heavy. If I had a ton of cash and a local header fabricator I think it would be cool to build one in my show truck.
jones
Post  IDT-572 June 20th 2014, 9:19 pm
schmitty wrote:
Too heavy......
About 1.8 inches worth on the deck doubt it would be more than 30 lb.
Post  schmitty June 20th 2014, 9:25 pm
I can't imagine even 50# being a deal breaker if you could have over 750 ci for a drag only deal.
Post  dfree383 June 21st 2014, 12:26 am
schmitty wrote:I can't imagine even 50# being a deal breaker if you could have over 750 ci for a drag only deal.
Takes a bunch of power to make up 50# on a 1900# dragster, when their are plenty if aluminum blocks around.
