BBF OEM Guru's
QtrWarrior
BBF OEM Guru's
I was looking at a Friends BBF yesterday and noticed something strange that he hadn't noticed. It didn't have a harmonic balancer OR a hatchet weight behind the 2 row belt pulley. It was a cammed up BB in a street driven car and it was smooth (no vibration at all). Whats the deal?
PS... It had C8 heads on it.
Re: BBF OEM Guru's
bbf-falcon wrote:I was looking at a Friends BBF yesterday and noticed something strange that he hadn't noticed. It didn't have a harmonic balancer OR a hatchet weight behind the 2 row belt pulley. It was a cammed up BB in a street driven car and it was smooth (no vibration at all). Whats the deal?
With some of the early stuff, the two row belt pulley was MORE than a pulley; it was a damper with pulley grooves.
Re: BBF OEM Guru's
Randy,this one looked to be just a pulley,but I can inspect it more.
Re: BBF OEM Guru's
What Randy said..
I have one on the shelf in the garage..
QtrWarrior- Posts : 2703
Re: BBF OEM Guru's
Rick I got a buddy with a c8 429 in a 67 F100 his is the same way he has been looking for a replacment but has had any luck finding the same kind. He parked his because it had slipped and his timing marks are off. Randy can a regular balancer replace that type or does it need to be the same kind. Like Rick said it the only one I have seen like that.
Re: BBF OEM Guru's
Damper Dudes offers them for $96 with a core exchange, unless Mike wants to sell you his...69F100 wrote:Rick I got a buddy with a c8 429 in a 67 F100 his is the same way he has been looking for a replacment but has had any luck finding the same kind...
Re: BBF OEM Guru's
Thanks Paul I will let him know
Re: BBF OEM Guru's
There are several damper re-builders who can rebuild one of those.
I have a "special" small block early damper put together to get near a 50 in/oz with 3 bolt pattern; to put a later 302 engine into a pre-1970 vehicle ... (a 60's 28 in/oz center with a late 70's 28 in/oz outer ring).
Re: BBF OEM Guru's
Thx Guys for the replys. If they came like that,then I guess its ok,I just hadn't seen any STOCK oem ones like it. Never get to old to learn something new.Thx Guy's
Any prehatchet (internal)balance HB should interchange.Right?
Re: BBF OEM Guru's
Of the zillion 429-460 I've seen only one of them had the grooved dampner.....it's a wierd looking deal.
Re: BBF OEM Guru's
68'-69' 429-460's had the double grooved dampers. Reason being they have the shorter early (C8SE) water pump and is what needed for the pulleys to line up. The A/C pulley bolted on. The Boss 429 also used the early short water pump, but used a shorter crankshaft snout to space the damper back and used a bolt on pulley. 70 and up used the longer water pump and damper setup. You can change over to the 70 style front dress and damper. The early setup give a little more clearance to the radiator.
466cj- Posts : 391
Re: BBF OEM Guru's
Thx Guy's. I had a closer look at the engine today. It's got the damper that Paul has pictured. Thanks for the info,
