help with geardrive for my 460!
gmsmkr
greg_a_morton
help with geardrive for my 460! Empty help with geardrive for my 460!
Post  greg_a_morton June 22nd 2014, 7:24 pm
Guys I was looking on ebay at the different gear drives and noticed there are some with the center hole and dowel pin and others with 3 holes and a dowel pin. Is there a way of knowing with out tear down so I can go ahead and order? I do know my cam is a small rv style cam and its a later 70s engine with D3 heads. Its driving me bonkers not knowing what cam exactly is in there for tuning. My truck is heavy with 3.54s and c6 and would like better fuel mileage but unsure if 8mpg is ok with my setup. Also running around a 31-32" tire so nothing crazy there.
greg_a_morton
help with geardrive for my 460! Empty Re: help with geardrive for my 460!
Post  schmitty June 22nd 2014, 7:37 pm
Forget the gear drive stuff and just put a good early style straight up chain and gear set in it.  You will be a lot happier.
Post  greg_a_morton June 22nd 2014, 7:44 pm
my gear set is the early one set strait up! I have had 2 gear drives and love the whine. What is the negative in using the gear drives?
greg_a_morton
Post  gmsmkr June 22nd 2014, 8:04 pm
The gear drive is not needed unless your making big power.
Harmonics is the main reason the 3 hole gear drives advance at the cam its self as opposed to the crank.
gmsmkr
gmsmkr
Post  dfree383 June 22nd 2014, 8:27 pm
Gear drives are not needed at any power level.
Get a good chain.
Post  schmitty June 22nd 2014, 8:56 pm
gmsmkr wrote:The gear drive is not needed unless your making big power.
I've seen a ton of N/A and Nitrous engines making well over 1250 HP and not a single one of them had a gear drive.
Post  greg_a_morton June 22nd 2014, 9:10 pm
Im not understanding yall I guess. What is the disadvantages of the gear drive? does it use more power to run it over a chain?
greg_a_morton
Post  schmitty June 22nd 2014, 9:15 pm
There is no reason to spend big dollars on a gear drive that is noisy and transfers a lot of bad harmonics when a simple cheap chain and gear set up works so well.
Post  gmsmkr June 22nd 2014, 9:16 pm
I just put my 2cents in on the mater....1250 is not a lot of power in my book sorry I even posted...
gmsmkr
gmsmkr
Post  schmitty June 22nd 2014, 9:22 pm
I guarantee Kasse and Sonny don't put them on their engines either.
Post  greg_a_morton June 22nd 2014, 9:23 pm
There $50 to $100 now.
greg_a_morton
Post  schmitty June 22nd 2014, 9:26 pm
You are more than welcome to spend your money as you wish, but you will be doing yourself a disservice by putting one in your engine.
Post  gmsmkr June 22nd 2014, 9:30 pm
Nope its called a belt drive  Laughing
gmsmkr
gmsmkr
Post  schmitty June 22nd 2014, 9:34 pm
Now we're stepping into the latest century as far as high performance engine technology.
Post  gmsmkr June 22nd 2014, 9:39 pm
To the op you can get a good used chain set just keep a eye out for them...
gmsmkr
gmsmkr
Post  greg_a_morton June 22nd 2014, 9:44 pm
just trying to learn... So the harmonics cause timing issues?
greg_a_morton
Post  dfree383 June 22nd 2014, 10:18 pm
greg_a_morton wrote:There $50 to $100 now.
IMO I wouldn't run a cheap Chinese part in that position in anything I put together.
The gear drive stuff for that money is not very good. Poor materials, machining and fitment.
A quality $90 billet chain with a German chain is a much better choice.
Post  IDT-572 June 22nd 2014, 10:23 pm
If that's what you like, for the noise run it............ I have ran them years ago and they ran fine, but I'm like the other guys, a good chain set up is what I run. There will be some harmonics that could cause spark scatter and valve train harmonics, but I doubt with what your running it will be noticeable.
Carry on...........
Post  jones June 22nd 2014, 10:30 pm
The OP sounds a lot like me!
I want to run Interco Boggers on my truck just so people can hear them coming 4 miles down the road! LOL I have thought about the gear drive as a super cheap "roots blower". If the OP just like to hear a whine it would be his cheapest option! Heck, I know a lot of my friends that run blown alcohol setups, that like to run them fat just so spectators move away and it hunts rpm!
jones
Post  cool40 June 22nd 2014, 11:26 pm
i ran one years ago with no problems @7500 rpm.  Cool
Post  jones June 22nd 2014, 11:32 pm
greg_a_morton wrote:just trying to learn...  So the harmonics cause timing issues?
A three gear setup is much better than a four gear.
jones
