canton pan for BBF USED
CHASSIS DRAG POWER PAN (13-766)
This Ford 429-460 drag race flat bottom Pro Power pan is designed for chassis without x-members or steering links under the engine. It is 7-1/2" Deep in front and 8" Deep in the rear and holds 8 qts., system capacity is 9 qts. The large oil recovery pouch requires the right side mounting bolts to be accessed through plugs in the bottom of the pan. This pan requires our 13-769 pickup. Will work with late model stock starters. Modifications needed for use with some aftermarket blocks.
The Pan Features:
* Triple Trap Door Baffles
* Pro Style Oil Recovery Pouch
* Midsump Pickup Compartment
* Provision For Our Pan Mounted Dipstick
* Magnetic Drain Plug
Our Price: $456
used 250.00 shipped with pick up
The Pan Features:
Our Price: $456
studly- Posts : 512
Re: canton pan for BBF USED
IS this the old style or the new style? Or how old is it? the old style has all the oil pan bolts on the right side. the new style you have to put 2 of them through the pan and then install two NPT plugs in the bottom
Ace
Ace
powerstrokeace- Posts : 1496
got the two npt pipe threads in the bottom
studly- Posts : 512
I can email Pics i do not know how to post pics on this site
studly- Posts : 512
I have the same pan. Do you have the windage tray that bolts to the main caps? I have the older version as well and was hoping to find that one as mine cracked and so far we have not had any luck repairing it and ended up buying the new one. We also lost a little performance and was hoping to find the older pan and put it back on to see if the performance came back.
Ace
Ace
i do not have the windage tray just the pick up and pan. sorry
studly- Posts : 512
still for sale
studly- Posts : 512
» canton pan
» canton oil pan
» New Canton oil pan and pickup
» Canton BBF foxbody pan
» Canton BBF oil pan
» canton oil pan
