brake problems
brake problems
got an 1989 f-150, i got rid of the booster for the master cylinder. I replace the manual master cylinder, but the truck will not stop, any ideas?
pigs521bbf- Posts : 173
Re: brake problems
did you change the ratio on the pedal? correct length push rod?
Re: brake problems
yea i did that. The brake lines are fine
Re: brake problems
I have bled the brakes and the pedal is hard when push it in...
Re: brake problems
you used the correct manual parts, not the power brake parts? Just swaping the master won't cut it.
Re: brake problems
ok so what do you mean? sorry kinda lost
Re: brake problems
Define "will not stop". Like it won't stop at all or is the pedal just hard? A hard pedal requires a smaller bore master cyl. Manual brakes usually have a different pedal ratio as well. That is why Dave is asking if you switched the pedal as well as the m/cyl. The manual brakes are harder so the pedal will give you more leverage making the pedal easier to push down.
jasonf- BBF CONTRIBUTOR
» ENGINE RPM DROPS & ENGINE DIES AT IDLE & BRAKE PROBLEMS
» Trans Brake vs Foot Brake
» MSD PROBLEMS?
» problems with 460
» oil psi problems
» MSD PROBLEMS?
» problems with 460
» oil psi problems
