My Ford Contour
My Ford Contour
My son has a 2000 Ford Contour with a 2.5. Was running like Ka Ka with a check eng light. I pulled the code and got a P1405 which is a DPF sensor
http://ww2.justanswer.com/uploads/jettadan1/2011-11-09_042718_fullshot.pdf
Replaced the sensor and the hose keeps popping off. Replaced the hose and it keeps popping off. Its the upstream pressure hose...
I hate to replace the cat if I am not sure that's the problem. I suspect if the cat is plugged it will create excessive pressure on the upstream pressure hose causing it to blow off.
And input?
Tom
And input?
Tom
747JetMech- Posts : 272
Re: My Ford Contour
If the Cat is plugged it will be down greatly on power and the inlet to the cat will be glowing RED in the dark. I don't think thats the problem.
Hi Rick
I wonder if a guy can use a thermal hand held scanner to check the cat. I thought I read that somewhere. I will run the snot out of it tonight and look at the cat in the dark to see if its glowing.
Re: My Ford Contour
Typically if the cat con is plugged, there will be very little exhaust flow out the tailpipe
Alot of times it will blow out a flange gasket and make a whistling noise
NOS42- Posts : 588
Re: My Ford Contour
747JetMech wrote:I wonder if a guy can use a thermal hand held scanner to check the cat. I thought I read that somewhere. I will run the snot out of it tonight and look at the cat in the dark to see if its glowing.
Yes,I use that method. And yes,very little exhaust will will exit after it gets hot.
Re: My Ford Contour
Didn't realize any of those were still out there.
crittersf1- Posts : 521
There not unless you work on them all the time
It went to the wrecking yard out here looking for a front clip. (Fell asleep on the way home from work). Anyway, all the contours and mystiques, all died with in 30k of each other. It was around the 150k point..
Re: My Ford Contour
I've had a few Contours and they were good cars. I've also crushed about 10.
» We had a forum member set low ET for a Ford at the Annual Ford v Chevy race last weekend.
» Let's see your "unusual"Cool HotRod pic's. Ford and Non Ford
» 6.7L Ford ...............................
» big block ford parts,and sb ford
» FS: 1967 Ford Custom 2 door sedan with '67 Ford Custom parts car (Galaxie body)
