.904 lifters
.904 lifters Empty .904 lifters
Post  AL Q July 19th 2014, 10:17 pm
Has anyone installed.904 isky lifters in a D0VE-A block without bushings? And if so was there any issues?
Thanks, Al
AL Q
AL Q
.904 lifters Empty Re: .904 lifters
Post  Curt July 20th 2014, 12:34 pm
If you're boring the lifter bores, why would you not put bushings in??
Post  AL Q July 20th 2014, 1:04 pm
Curt wrote:If you're boring the lifter bores, why would you not put bushings in??
I don't know why, kinda why I'm asking. Why doesn't the factory or any other block manufacturer put bushings in when they bore ?
AL Q
AL Q
Post  QtrWarrior July 20th 2014, 2:16 pm
Why don't they ??
Added cost to manufacture!
Stockers didn't need them in their previous life in passenger cars..
Aftermarket, the need for them depends on your use, Would you need them, if you were running a Hyd. Cam ???
QtrWarrior
QtrWarrior
Post  cool40 July 20th 2014, 3:05 pm
Why would you need a bushing? I may need them and don't know it yet but never had any. They may be easier on lifters?  study
Post  Curt July 20th 2014, 4:03 pm
A race engine puts a lot of loads on parts that you'd never see on a production model.
Do you need bushings,,,,,, probably not.
Do you need .904 lifters,,,,,, probably not.
If you do need one, the other should follow. IMHO, I mean if you're already doing the work to make the holes bigger.
I would rather place a load a piece of bronze than a piece of steel.
As Clint Eastwood would say "A man has to know his limitations".
.904 lifters Newbuild3
Post  cool40 July 20th 2014, 5:28 pm
I suppose it would depend entirely on the application....if it aint broke dont fix it comes to mind. Im not sure who said that.  Laughing it would make for easy repair if one had lifter problems later.
Post  Bret Powell July 21st 2014, 11:10 pm
If you are not class limited, why would you spend the money on a stock block for bushings?
Bret
Bret Powell
