Black rtv for seam sealing
+6
nuclearcobra
yellowhorse7
whitefield
tconnection
10 posters
I got my mini tubs in and didnt know what kinda sealer to use. I messed around and used black rtv on the direct metal. I got that rust film. Do I need to remove it and treat the metal or would rust treatment take care of it?
tconnection- Posts : 866
Re: Black rtv for seam sealing
Has any of u guys done this and what did u do to fix it?
3M joint and seam sealer.
whitefield- Posts : 2244
If I have to strip this rtv out I will go back with the 3m stuff. Im needing info on the issue I have accumilated.
Has any of u used the rtv like I did?
whitefield wrote:3M joint and seam sealer.
I agree
I have used the rtv like you did it just not very paintable
What did u do about the rust issue?
tconnection wrote:What did u do about the rust issue?
I would strip it oit and wire brush the rust area. Once the seam sealer is on and has COVERED the bare metal, it won't rust unless the area is humid. I always paint the joint ASAP
yellowhorse7- Posts : 1382
yellowhorse7 wrote:tconnection wrote:What did u do about the rust issue?
X2 you can also strip out and clean it good and prime and paint and then seal it and then repaint it with a top coat
Clean it all off and brush some por15 on then use the 3m stuff.
I would paint with some rustoleum , my Dad retired at 50 from Union Carbide ( Linde divison) and he said they let a light rust start on the new tanks and then paint with them with Rustoleum [only] for the longest lasting finish they've found over the years.
nuclearcobra- BBF CONTRIBUTOR
https://2img.net/h/i195.photobucket.com/albums/z169/nuclearcobra/IMG_3362.jpg https://2img.net/h/i195.photobucket.com/albums/z169/nuclearcobra/IMG_3371.jpg
that's gloss black and black 50yr caulking I used for seams on the rear firewall and the metal I put in.
A light rust is interesting. Never would have thought of that.
Dave C.- Posts : 1268
I was told once not to use silicon on bare sheetmetal because it would cause it to rust out. I did not and still do not understand why but never was willing to test the theory.
lghting94- Posts : 762
O got the rtv stripped off and picked and picked in between tacks and wire brushed good. I spray ed it with permatex rust treatment and it turned black.
All silicone based sealers will cause oxidation on bare metal.
jbozzelle- Posts : 3705
Yep I always loved to see a car come in with it all around the windshield. Lol
cool40 wrote:Yep I always loved to see a car come in with it all around the windshield. Lol
Yep,thats always fun.
» sealing a fuel line
» Sealing header gaskets
» Bad A Fords at NMCA World Finals-Pics Added
» Big Black C........
» New A Head Intake Gaskets with Sealing Bead
