Traction Control
yellowhorse7
79Puller
Traction Control Empty Traction Control
Post  79Puller July 23rd 2014, 2:05 pm
I hear alot about this, it is even to be used in a few pulling trucks around my area . Can someone explain how it works ( timing ) and what is it really called and who makes it. Thanks
79Puller
Traction Control Empty Re: Traction Control
Post  yellowhorse7 July 23rd 2014, 8:35 pm
79Puller wrote:I hear alot about this, it is even to be used in a few pulling trucks around my area . Can someone explain how it works ( timing ) and what is it really called and who makes it. Thanks
Just Google Davis Box and read the different options on the site
yellowhorse7
yellowhorse7
Post  bbf-falcon July 26th 2014, 7:29 am
I wouldn't think traction control would be a good idea in a pulling deal.
Post  maverick July 26th 2014, 12:42 pm
bbf-falcon wrote:I wouldn't think traction control would be a good idea in a pulling deal.
Yeah. I don't know much about it but "wheel speed" seems to be a pretty big deal to those guys.
Post  schmitty July 27th 2014, 1:24 pm
Traction is still the name of the game even in pulling competitions. Weight distribution, tires, and leverage all come into play also, but you have to manage traction to get the most out of every pull.
Post  bbf-falcon July 27th 2014, 2:37 pm
True,but I haven't watched a good pulling truck that wasn't spinning the tires the distance of the pull.
Post  cool40 July 27th 2014, 2:51 pm
I would be very interested in seeing a pulling truck with it.. Suspect
Post  whatbumper July 28th 2014, 1:18 pm
You dont have to set up the traction control to stop spinning. You can set a predefined driveshaft rate which could be spinning the tires but not let it climb above a predefined rate.
Post  bbf-falcon July 29th 2014, 9:01 am
whatbumper wrote:You dont have to set up the traction control to stop spinning.   You can set a predefined driveshaft rate which could be spinning the tires but not let it climb above a predefined rate.
That might work. Smile
Post  David Cole July 29th 2014, 1:53 pm
Davis:
http://www.moretraction.com/traction.htm
