Snakebit
Dark Horse of Apocalypse
Snakebit Empty Snakebit
Post  maverick August 9th 2014, 12:31 pm
Yesterday's weather prediction was for rain today...but it looks like it'll be clear enough for a big day at the track. A ProMod Big Dawg shootout, a Big Tire shootout, a Small Tire shootout, 6.0 index, 7.0 index and crotch cars. Gonna be a packed house. Cool
So I moved the car from the garage to load up...and there's big ol' puddle of gear oil under the 9". Why me, Lord?  Rolling Eyes
Snakebit Empty Re: Snakebit
Post  Dark Horse of Apocalypse August 9th 2014, 12:49 pm
Wow hate to hear that but it happens in business also.
There are days I questions my sanity & why I got outta bed. Mad Rolling Eyes Wink
Post  bbf-falcon August 9th 2014, 3:31 pm
2014-08-09
maverick wrote:Yesterday's weather prediction was for rain today...but it looks like it'll be clear enough for a big day at the track.  A ProMod Big Dawg shootout, a Big Tire shootout, a Small Tire shootout, 6.0 index, 7.0 index and crotch cars.  Gonna be a packed house. Cool
Should be a easy fix Kim. I usually either use oil dry if there's alot,if not i use a rag then clean the floor w/brake cleaner. Wink drunken
Post  69F100 August 9th 2014, 9:15 pm
Might be good you found it now than when you hitting 100+ mph and it get slung under the slicks  Embarassed Embarassed
Post  maverick August 9th 2014, 10:26 pm
bbf-falcon wrote:2014-08-09
Thanks for the hot tip, Rick. I guess I had thatt coming as you usually get a smartass from me. Razz
Actually, it looks like the pinion seal. I'll get under it tomorrow.
Post  maverick August 9th 2014, 10:30 pm
That's no joke right there. I split a trans cooler line in the Ranger once...I took Mr. Toadie's wild ride and ruined my shorts.. I also noticed my popularity had suffered a bit when I got back to the pits. Who knew oiling the track was uncool??
Post  maverick August 9th 2014, 10:41 pm
I rode by the track on my way back from Mobile tonight. The place is packed from fence to fence and lit up like Disney World. Hate missing that one. Mad
Post  cool40 August 9th 2014, 11:21 pm
maybe its a pinion seal so you can fix it easy.it could be like my trans yoke....sob wont leak unless it sets a few months. it never did that before so i guess i should get it to the track more often!  Embarassed
Post  69F100 August 10th 2014, 12:16 am
cool40 wrote:maybe its a pinion seal so you can fix it easy.it could be like my trans yoke....sob wont leak unless it sets a few months. it never did that before so i guess i should get it to the track more often!  Embarassed
My 69F100 is the same way done put 2 seals in it changed yokes I think the bushing is causing mine to leak as it don't get drove much if I drive it every day it never leaks  scratch
Post  69F100 August 10th 2014, 12:30 am
True I had a oil line come off the 460 on top end  Embarassed  One thing if I find a oil leak I load mine up I don't want to wreck mine an don't want to be the cause someone to wreck and mess up their ride because I put oil on the track. It easier to fix a oil leak than have to fix the oil leak and the truck from keep on running it with the oil leak.
Post  maverick August 10th 2014, 6:04 pm
Simpler than that.  The bottom of the housing, the carrier to mounting flange, the pinion support and the pinion seal are all as dry as toast.  I crawl around, looking, feeling for something slippery (sounds dirty, eh?).  The only place there's oil is INSIDE the center of the pinion yoke.  Apparently it's wicking oil along the splines.  Pinion nut is still as tight as Dick's hat band.  I never had one leak there before Suspect ...maybe it's a little overfilled?  BTW, this is a Fab9 housing and a Strange aluminum carrier. What do you guys think?
This pisses me off no end, as I missed a helluva race for this.
And who the hell is this "Dick" guy, and how come he never learned how to buy the right hat? Rolling Eyes
Post  bbf-falcon August 10th 2014, 6:22 pm
Kim, I hope you can find the leak brother,sorry i had to  Razz you abit. You owe me one. Laughing
Post  maverick August 11th 2014, 1:47 pm
Just to reassure myself that there's no problem, what do you guys think? I've been running 9" rears for decacdes and this is the first one to leak from behind the pinion nut. Common? Not so common? Overfilled? Suspect
Post  cool40 August 11th 2014, 9:21 pm
i went through the leaking spline when i was changing gears a few times in my old car.i did the same thing i do for the axle bearings,healthy bead of silicone!
Post  maverick532 August 11th 2014, 9:34 pm
this is not an uncommon problem have seen this on various rear end types and not limited to ford differentials .
maverick532
Post  maverick August 12th 2014, 8:30 am
Looks like I've just been lucky for a long time. Silicone it is. Thanks, guys.
Post  dr's wife racing August 12th 2014, 10:15 am
I've felt with this before. Silicon is  the answer. Might want drop the pub level a bit.  1 quart is plenty to race with.
dr's wife racing
dr's wife racing
Post  maverick August 12th 2014, 10:50 am
dr's wife racing wrote:I've felt with this before. Silicon is  the answer. Might want drop the pub level a bit.  1 quart is plenty to race with.
Yep. I figured as much. I'm gonna drain a little out. Been running 2 quarts. Thanks, Ward.
