MSD Distributor pickup or Crank Trigger
What way do most you go and set ups.
Northwest outlaw- Posts : 962
Re: MSD Distributor pickup or Crank Trigger
i see a few peolpe are running 8580 with a crank trigger why are people doing this? Why are they not running 8569
Well i guess you can run 8580 with the trigger and some thing happens to the trigger you can use the dis... didnt think about that what your guy intake on this?
Cool little right up on
A Cam Sync if you are running a 7530,7531,7535 and want cylinder controul with a crank trigger.
www.candbmotorsports.com look in the tech
I suspect they have a 8580 that is bought and paid for....rather than buy a special 'trigger' diz they use the lock out feature of the 8580 and leave the pickup wire unhooked .Northwest outlaw wrote:i see a few peolpe are running 8580 with a crank trigger why are people doing this? Why are they not running 8569
I found that the 8569 fouled on a SVO B460 intake manifold might be the same on A460 intake not sure about other head/manifold configurations?
XYPROSTREET- Posts : 35
» Crank trigger distributor
» MSD stubby crank trigger distributor
» MSD 8569 Crank trigger Distributor
» WTB MSD 8569 crank trigger distributor
