Progressive controller
Progressive controller Empty Progressive controller
Post  kjett August 19th 2014, 8:27 am
Thinking of adding a 2nd stage over the winter and want to get the correct parts beofre the trial and error happens. Plan is to go fogger with a plate 2nd stage. Looking at adding a progressive nitrous controller to help control blowing the tires off at launch. Keep in mind, I'm in a mud drag truck, not pavement. My big question is looking at the NOS Mini and Launcher they both make reference to adjusting the TPS. I'm assuming they are only set up to work of fuel injected setups, so is there a way to connect one to a carb'd setup? Really new to the whole nitrous game. Just been beating on the single plate for the last couple of years.
kjett
kjett
Progressive controller Empty Re: Progressive controller
Post  richter69 August 19th 2014, 8:58 am
They work with carbed set up, tps is just the micro switch on the carb.
Post  kjett August 19th 2014, 8:59 am
Sweet. I know you have the mini, so I might have to hit you up on some questions when I get it and wire it up...
kjett
kjett
