Aftermarket yoke
bosshoss
Aftermarket yoke
Where can you get a 1410 yoke for a 10.25 sterling rear pinion. Also a rear 1410 yoke for a 1356 transfer case?
Re: Aftermarket yoke
Have you talked with Yukon or Strange?
No. but I will.
There was a flange for the rear and you should be able to get a 1410 yoke for it. Mark Williams has the T/C yoke.
schmitty- Posts : 4538
http://www.ringpinion.com/b2c/ProductDetails.aspx?ProdID=302&Product=YY_F100605&Brand=Yukon_Gear_and_Axle
http://www.ringpinion.com/b2c/ProductDetails.aspx?ProdID=303&Product=YY_F100604&Brand=Yukon_Gear_and_Axle
dont see anything on the transfer case yoke but give them a call.
dkp
dkp
bosshoss- BBF CONTRIBUTOR
schmitty wrote:There was a flange for the rear and you should be able to get a 1410 yoke for it. Mark Williams has the T/C yoke.
Mark Williams don't have the T/C yoke I'm still looking for it. . I found the rear end yoke Randy's Ring and Pinion had it.
One of these work?
http://www.northerndrivetrain.com/category/cat_endyokes_splined_31splines_1-343-31Involute.html
http://shop.broncograveyard.com/1980-96-Ford-Truck_Bronco/departments/20/
check out this site Blake , they have all of this it looks like
Be aware there are two different length splines on 10.25's ......
and ..... 10.25 pinions are weak....
Brandon
Brandon
hookin78- Posts : 58
Thanks Brandon,
I have found all I need, but I am changing rear ends, not sure yet what I am going to though.
Greensburg machine is a great source. I bought a lot of driveline parts from them when I was pulling.
http://www.greensburgmachine.com/index.html
