turbo cheetahs shifter?
lghting94
stanggt
turbo cheetahs shifter? Empty turbo cheetahs shifter?
Post  stanggt August 31st 2014, 8:09 pm
Having an issue adjusting cable so gear selection matches up with gate. C4 reversed manual valve body. Reverse hits between P and R. Followed instructions pulling shifter all the way down to 3rd as well as trans selector and adjust cable to the hole. Anyone deal with these shifters?
stanggt
stanggt
turbo cheetahs shifter? Empty Re: turbo cheetahs shifter?
Post  lghting94 August 31st 2014, 9:39 pm
Only way I ever got mine adjusted was to put tranny in neutral, shifter in neutral and adjust cable there. Make sure it lines up perfectly. My trans was a c-6.
lghting94
lghting94
Post  stanggt August 31st 2014, 9:43 pm
I will try that then. Thanks
stanggt
stanggt
Post  AL Q September 2nd 2014, 11:44 pm
I'd say you have a gate plate for a GM trans
AL Q
AL Q
Post  stanggt September 3rd 2014, 12:03 am
I ordered it for c4 reverse manual. Funny thing is that I can pop cable out of shift lever that came with shifter and installed, pull shifter into any of the gears and then put shift selector on trans in same gear and cable end slips right into it with no issues.
stanggt
stanggt
Post  87mustang514 June 27th 2015, 4:59 pm
I have the same shifter , no problems , reverse shift pattern
87mustang514
http://Jerrysullivan45@gmail.com
Post  crittersf1 July 29th 2015, 4:30 pm
Mine has always worked perfect!
crittersf1
crittersf1
Post  DGS August 8th 2015, 10:34 pm
Best 3 speed shifter on the planet IMO. Adjust cable in first if manual valve body, or third if stock valve body. Adjusting in neutral should work also. You sure you have the right shift lever on the trans?
DGS
DGS
