Are You Folks Using?
+8
kjett
gmsmkr
whitefield
Dark Horse of Apocalypse
12 posters
Are You Folks Using? Empty Are You Folks Using?
Post  Dark Horse of Apocalypse September 2nd 2014, 12:40 pm
Are you folks using TH400 or 4L80E trannys behind 429-460 BBFs?
Are You Folks Using? Empty Re: Are You Folks Using?
Post  maverick September 2nd 2014, 3:28 pm
for what purpose? My BBF is a race only thing...strictly Powerglide.
Post  69F100 September 2nd 2014, 3:45 pm
maverick wrote:for what purpose?  My BBF is a race only thing...strictly Powerglide.
X2
Post  dfree383 September 2nd 2014, 4:07 pm
2 speed automatic racing transmission...... tongue
Post  whitefield September 2nd 2014, 5:20 pm
1st gear is power 2nd gear is glide ! lol!
whitefield
whitefield
Post  gmsmkr September 2nd 2014, 7:34 pm
Yep glide here as well
gmsmkr
gmsmkr
Post  Dark Horse of Apocalypse September 2nd 2014, 7:44 pm
My understanding is racing generally involves a two speed tranny but in terms of a street strip car wouldn't a TH400 or a 4L80E be better.
Post  kjett September 2nd 2014, 9:51 pm
I like my rollerized c6, but then again, I'm in a mud drag truck
kjett
kjett
Post  schmitty September 2nd 2014, 10:02 pm
Dark Horse of Apocalypse wrote:My understanding is racing generally involves a two speed tranny but in terms of a street strip car wouldn't a TH400 or a 4L80E be better.
Why would they be better?  A rollerized C6 is darn tough to beat(I'm putting 1000 lbs of torque through mine), and if you need O/D, an A4OD can be made pretty tough, and you don't need a crossbreed converter or adapter plate.
Post  richter69 September 2nd 2014, 11:33 pm
only way id do a t400 is if it was a 2speed deal....... I doubt your in that territory though.
Post  maverick September 3rd 2014, 8:43 am
I guess that depends on how badly you think you need that low first gear.  Any self respecting BBF has no trouble getting a car moving....in ANY gear.  As long as you're not using a stock type converter, it WILL NOT hook on the street, and more low gear multiplication ain't gonna help.  A stock 1.76 first gear powerglide will probably fry the hides with a tap on the throttle. That leaves out the TH400 IMO, because high gear is 1 to 1, just like the 'glide, so you gain nothing there.
For me, the question then becomes, "Do I need overdrive or not?"  If it's a highway car, use the OD of your choice. If it's a town cruiser/track car.....powerglide.
Simple, effective, lightweight, tough, parts are evreywhere, my sister could overhaul one in an afternoon, makes a better track car, can be built to handle power levels from wimpy to "OMIGOD".............
JMO...
Post  Dark Horse of Apocalypse September 3rd 2014, 8:51 pm
Thank you all once again as I was under the mistaken impression I needed a 3 speed or 3X2 with a Gear Venders setup for a Street/Strip car. I guess the Ford I will own won't have Chebby part #s.
Post  Frank Merkl September 4th 2014, 3:17 am
I run a FORD C6 , Toughest trans out there!!! 200 Passes without changing clutches @ 2500hp , rollerized its almost bullet proof, front planetary needs to be changed out ever 100 passes as it takes a beating from tire shake as it kills the needles on the pinion gears . and this is a 2800Lb car with a 632 C headed BBF with 2 big stages of GO Juice!!!!
Post  maverick September 4th 2014, 8:54 am
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Cool
There's no doubt, Frank builds the baddest C6's around if you're inclined to go that way.
Post  Dark Horse of Apocalypse September 4th 2014, 11:08 am
Frank Merkl wrote:I run a FORD C6  , Toughest trans  out there!!! 200 Passes without changing clutches @ 2500hp , rollerized  its almost bullet proof, front planetary needs to be changed out ever 100 passes as it takes a beating from tire shake as it kills the needles on the pinion gears . and this is a 2800Lb car with a 632 C headed BBF with 2 big stages of GO Juice!!!!
maverick wrote:^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Cool
Sounds like a C6 for the street and the win.
Post  Frank Merkl September 9th 2014, 8:08 pm
Yea , We run a Street Car ! 2800 lbs it's plated and insured !! 7.20-30's @ 210mph with a C6
Post  jones September 9th 2014, 9:25 pm
The only thing the turbo 400 has going for it is weight. I looked into using one and the builder was adamant about not using 1st for burn-outs or down shifting the trans at high mph.
jones
Post  Dark Horse of Apocalypse September 9th 2014, 11:04 pm
Frank Merkl wrote:Yea , We run a Street Car ! 2800 lbs it's plated and insured !! 7.20-30's @ 210mph with a C6
jones wrote:The only thing the turbo 400 has going for it is weight. I looked into using one and the builder was adamant about not using 1st for burn-outs or down shifting the trans at high mph.
Awesome selling points for the C6.
Post  IDT-572 September 10th 2014, 6:11 pm
A good 460 with a C-6 and the correct converter won't hook on the street with a 2.78 rear gear. Evil or Very Mad Laughing
Post  Dark Horse of Apocalypse September 10th 2014, 6:21 pm
IDT572 I hear the same thing about Fox Mustangs and 460's. tongue Suspect Wink
