Change of intake for my street car
manofmerc
Dave C.
busta
Hey guys,
I posted in the tunnel ram on the street thread. Currently I have a 532ci bbf with ported D3 cast iron heads. They are ported to flow enough air to support 650hp. I used a fairly big solid roller, but don't have the specs on me. Compression ratio is 11:1 and it runs on pump fuel. The engine makes 650hp/675 ft lb with the tunnel ram. Unfortunately I had some issues with the police last week, and as such, I need to change the intake and carb setup to keep it all under a scoop.
I have had so many different opinions on intake, I don't know what to go with. As long as I make 600hp, I will be happy. What intake would you use for a street engine as described above?
- Blue Thunder dual quad intake ( I currently have 2 950 cfm carbs/linkage kit/fuel lines and reg for tunnel ram )
- RPM Air Gap
- Victor 460
- Other
Also, if changing to a single carb intake, what sort of carb would you use and from where?
- RPM Air Gap
- Victor 460
- Other
busta- Posts : 28
Re: Change of intake for my street car
I like the air gap .. Put one of the 950's on it. Sell the rest.
Dave C.- Posts : 1268
A close friend who I trust said the same thing. Air gap and a big 4150. I was leaning towards this combo over the Victor/dominator.
The mechanic down stairs said go the Victor with a dominator.
busta- Posts : 28
Rpm versus victor
That performer rpm is a good intake .On my 466 powered 67 comet bracket car I swapped it out for a victor it picked up .015 and maybe 1-2 mph this is with a quick fuel 950 and 6000 rpm shift point .In your case with that many cubes if you have a dominator carb go with a victor and if your application is more street oriented and you don't have a dominator go with the performer rpm air gap .Just my two cents .Doug
manofmerc- BBF CONTRIBUTOR
Use a ported dual quad "Blue Thunder" and keep both carburetors for the "look" and still make the power you are making now with better street manners.
rmcomprandy wrote:Use a ported dual quad "Blue Thunder" and keep both carburetors for the "look" and still make the power you are making now with better street manners.
Busta;
You asked me to post pictures of my Blue Thunder, dual quad intake with carbs and intake and the reason I didn't is that I don't know how. Sooo, I am going to call a person who knows how to and learn. Pictures will be posted shortly.
DanE- Posts : 90
Pic of the blue thunder intake and carbs
Blue thunder intake and carbs.
DanE- Posts : 90
Holley carbs will fit on that intake also as long as you change to regular side hung float bowls.
I'm voting for a Victor and an 2 circuit 1150 dominator...... Keep it simple and make power.
dfree383 wrote:I'm voting for a Victor and an 2 circuit 1150 dominator...... Keep it simple and make power.
X2
X3 I would convert the dominator to run E-85 on the street! JMO!!
butterbean- Posts : 676
» How often to change ATF on a street car?
» Intake change, Stealth to Torker II Done !
» intake, cam,carb change. your thoughts?
» Intake for 572 street engine
» mafia intake and tfs street alum heads
