External balance flex plate
External balance flex plate Empty External balance flex plate
Post  460bronco September 18th 2014, 3:37 am
Ok-- here's what I've got--- on the very first start-up of my 523, the motor kicked back and broke several teeth off the flex plate. This has happened about 2 more times in the life of the motor and now I have a few spots w/ teeth missing.
Question is- rotating assembly consists of a cast Skat 4.3" crank that was balanced internally in the front and externally in the rear. It looks like the balance was achieved by drilling 2 holes in the stock weight that is attached to the flex plate-------- can I simply purchase another Skat external balance flex plate and copy the drilled holes to maintain the balance of my entire rotating assembly?
Thanks,
Jon
460bronco
460bronco
External balance flex plate Empty Re: External balance flex plate
Post  the Coug September 18th 2014, 8:20 am
the Best way to do it is to get the machine shop that did the balancing in the first place they should have the balance sheets to redrill the flywheel...
Post  bbf-falcon September 18th 2014, 12:03 pm
Better be fixing the kickback problem also. Very Happy
Post  460bronco September 18th 2014, 7:34 pm
External balance flex plate 19f4f77f5acb73df95ca9eeaae8b6b1a_zpsecccb2ee
Looks like this shop left that little piece of info off???
460bronco
460bronco
