C-6 Transmission/ TB problems
kjett
pigs521bbf
I jacked up my truck, i have installed my c-6 4x4 transmission with frank's TB. I wanted to make sure the transmission was going into all of the gears. I have notice when I would put the truck into 1st gear, the wheels would turn (but in reverse?) and it would only spin if the transbrake button was pushed in... When you would release the TB button, the wheels will not turn...
Any thoughts about what is going on??
thanks
thanks
pigs521bbf- Posts : 173
Re: C-6 Transmission/ TB problems
pigs521bbf wrote:I jacked up my truck, i have installed my c-6 4x4 transmission with frank's TB. I wanted to make sure the transmission was going into all of the gears. I have notice when I would put the truck into 1st gear, the wheels would turn (but in reverse?) and it would only spin if the transbrake button was pushed in... When you would release the TB button, the wheels will not turn...
thanks
It sound like a pro brake I have a pro brake and with the pro brake you have to hold the button in to back up
I am sure Frank will let you know if this is right on his brakes
you have something wrong in the trans , or it isn't one of my VB's
Frank Merkl- Posts : 1524
recheck your shifter adjustment you may be out 1 detent
Frank Merkl wrote:recheck your shifter adjustment you may be out 1 detent
^^^I'm betting this
kjett- Posts : 1169
kjett wrote:Frank Merkl wrote:recheck your shifter adjustment you may be out 1 detent
^^^I'm betting this
Me too.
crittersf1- Posts : 521
Well? What did you find?
They never say
Frank Merkl wrote:They never say
Where's the fun it that?
kjett- Posts : 1169
I know and some of us could learn from what the answer is or what they find.
whitefield- Posts : 2244
Hey guys sorry about not getting an update.. Life happened but everything is back to normal for the most part.
I took the trans out and called Frank about the problem and the Forward Clutch Drum was broken and thats why it would not go into any gear. Reverse was the only gear I had. We cleaned everything out and replace the drum and had to send the converter off to get it cut and clean because of the metal.
Sorry for the troubles , but glad you got it figured out and let us know what happened to it.
white field wrote:Sorry for the troubles , but glad you got it figured out and let us know what happened to it.
thanks! The truck runs good and shifts in all the gears lol.
WoW, how did that happen?
68formalGT- Posts : 865
Race pressures and old age drum
Is there a given time that those drums should just be replaced?Frank Merkl wrote:Race pressures and old age drum
the thing with the stock forward drum, you don't know it's life and how it's been treated , that's why I recommend the billet forward from TCS ,sure it's $700 but roll the dice , it's in your instructions with the vb
I had a drum just like that many years ago that came to me for a rebuild, was in an F100 pie truck , with stock C6 , split it right open ..
Gregaust- Posts : 625
» Question regarding SFI bellhousing for auto transmission, and Automatic Transmission Flexplate Shield
» problems with 460
» C6 problems
» C6. Slow shifting
» MSD PROBLEMS?
» problems with 460
» C6 problems
» C6. Slow shifting
» MSD PROBLEMS?
