Ford career for "GEAR HEADS"
anyone looking for a career change?
http://corporate.ford.com/careers?&ccode=US
Here is a good one for guys that have "dealer like knowledge"...
Job disc..
Auto req ID 13503BR
Job Title Engineering Technologist, Global Engine Engineering
Location Dearborn
State Michigan
Company Ford Motor Company
Job Description & Qualifications Position Duties:
Create, maintain, and update engine component, engine weight, and vehicle build matrices for each series of prototype engine builds.
Ensure prototype engine build content is consistent with program assumptions
Monitor engine matrix changes and coordinate necessary engine build updates with all affected activities.
Coordinate engine build / re-build / teardown activities at the engine prototype facilities.
Coordinate component bench testing activities.
Assist in setting up design aid engines and bucks. Coordinate hardware fabrication as necessary.
Initiate miscellaneous prototype parts purchases and follow up as necessary.
Assist engine dynamometer and bench test personnel with hardware support.
Provide engine hardware support to the prototype vehicle build activity.
Provide launch and stop ship support to the Vehicle Assembly Plants.
Actively participate in GEE product and process improvement activities.
Travel to various North American locations will be required; up to from 10 to 25% annually.
Minimum Requirements:
High School Diploma or Equivalent Required
Significant knowledge of engine function, troubleshooting, and repair (including full teardown and rebuild)
Excellent leadership, communication, and project management skills
Proven track record of integrity and a strong work ethic
Self-directed, able to analyze and solve problems.
Proven high level of written, verbal, and interpersonal skills
ASE Certified Mechanic or equivalent certifications and/or experience
Experience as a mechanic at an automotive dealership
Other Qualifications:
ASE Certified Master Mechanic is a preferred qualification, but not required
The distance between imagination and …. Creation. It can be measured in years of innovation, or in moments of brilliance. And, it can be a road you start traveling right now. When you join Ford Motor Company, your journey begins. You become part of a team that is already leading the way, with ingenious solutions and attainable products – and it is always ready to go further.
At Ford Motor Company, the distance between you and an amazing career has never been shorter. Join the Ford team today, and discover the benefits, rewards and development opportunities you’d expect from a diverse global leader.
Candidates for positions with Ford Motor Company must be legally authorized to work in the United States. Verification of employment eligibility will be required at the time of hire. Visa sponsorship is not available for this position.
Ford Motor Company is an equal opportunity employer committed to a culturally diverse workforce. All qualified applicants will receive consideration for employment without regard to race, religion, color, age, sex, national origin, sexual orientation, gender identity, disability status or protected veteran status. Ford Motor Company also is committed to take affirmative action to employ and advance in employment such persons.
Job disc..
Auto req ID 13503BR
Location Dearborn
State Michigan
blown86hallet- Posts : 1012
» Wanted..... Cast iron Blue thunder Ford port heads or CJ heads
» FS: New set of Ford M-6049-SCJA aluminum cylinder heads.. HEADS SOLD, Thx
» 3.73 gear set 8.8 Ford
» 3:73 gear ford 8.8
» Ford c6 first gear
