Guide plates
+6
hienergy557
460bronco
Tore
10 posters
Guide plates
Are the guide plates for the P-51 heads the same as the Ford SCJ Heads??
Tore
Tore
Tore- Posts : 865
Re: Guide plates
Should be..... But I've never tried. I've only used the ones Kaase supplied with the p-51s
Re: Guide plates
I thought the two heads had the same valve angles, but slightly different rocker arm stud locations?
460bronco- Posts : 364
Re: Guide plates
Tore wrote:Are the guide plates for the P-51 heads the same as the Ford SCJ Heads??
Tore
Not EXACTLY the same but, close enough to work OK.
Re: Guide plates
If the guides plates don't line up properly, always be willing to cut them in half, align everything, and then tig weld them back together. That means all types of heads, such as Blue Thunder, SCJ, Edelbrock, P-51 or any of them.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Re: Guide plates
I have cut and welded BT's & P51's because I wasn't happy with the alignment.
I've since gone to shaft rockers.
hienergy557- Posts : 179
Re: Guide plates
From my experience they're different...
jbozzelle- Posts : 3705
Re: Guide plates
If the stud girdles are different then the guides should be as well. My SCJ guides were way off. I hear that the P-51 guides are better fitting on P-51 heads.
Dave De- Posts : 797
Re: Guide plates
Dave De wrote:If the stud girdles are different then the guides should be as well. My SCJ guides were way off. I hear that the P-51 guides are better fitting on P-51 heads.
The stud girdles are different because the intake studs are at a different angle. The base of the stud is in the same location as those on a Ford Racing SCJ head.
Re: Guide plates
rmcomprandy wrote:Dave De wrote:If the stud girdles are different then the guides should be as well. My SCJ guides were way off. I hear that the P-51 guides are better fitting on P-51 heads.
That would make the guide plates head specific too, right? Or am I over thinking it?
Re: Guide plates
jbozzelle wrote:rmcomprandy wrote:Dave De wrote:If the stud girdles are different then the guides should be as well. My SCJ guides were way off. I hear that the P-51 guides are better fitting on P-51 heads.
The guide-plate is LOCATED at the BASE of the stud. They would have a slightly different "twist" but, will conform to the correct angle when the stud is torqued.
Re: Guide plates
rmcomprandy wrote:jbozzelle wrote:rmcomprandy wrote:Dave De wrote:If the stud girdles are different then the guides should be as well. My SCJ guides were way off. I hear that the P-51 guides are better fitting on P-51 heads.
That's the way i see it.
Re: Guide plates
c.evans wrote:If the guides plates don't line up properly, always be willing to cut them in half, align everything, and then tig weld them back together. That means all types of heads, such as Blue Thunder, SCJ, Edelbrock, P-51 or any of them.
Hope this helps,
Charlie
We had to cut and weld the guide plates on my P-51 heads.
Beast- Posts : 66
» Roller Rocker not hitting valve squarely
» guide plates
» Guide plates
» converting to roller rockers on C8VE heads
» Guide plates
» guide plates
» Guide plates
» Guide plates
