REED ALUM GLIDE CASE
REED ALUM GLIDE CASE Empty REED ALUM GLIDE CASE
Post  tconnection October 14th 2014, 12:20 am
Whats all needed to go inside a reed alum case? I mean I figure everything but like what drums which sprag would a stock planetary work? Thanks for any info.
tconnection
REED ALUM GLIDE CASE Empty Re: REED ALUM GLIDE CASE
Post  cool40 October 14th 2014, 12:43 am
I would think stock parts would fit but why? Thats like putting pump gas in a promod! Razz
Post  bosshoss October 14th 2014, 2:35 am
Try to find an old used up stock core.. then you can harvest the small hardware from that. Things like the pawl for the park brake and the little clamp that holds it etc are all available but I think the small parts kit is like 300 bucks or so from Reid or ATI
Parts selection on planetaries etc will depend on your projected power level... Stock stuff will work but wont last long if you apply much over 750 hp.
Lots of guys still use the stock drums and reverse pistons etc. modified to suit the number of clutches required. Stock servo cover works fine even at 250 psi line pressure. The billet ones look pretty cool tho Very Happy
dkp
bosshoss
bosshoss
Post  tconnection June 9th 2015, 11:44 pm
I need this tranny to handle at least a 1000hp.
tconnection
Post  tconnection June 10th 2015, 11:39 am
What oe parts that's in a glide need to be up graded to handle a 1000hp?
tconnection
Post  David Cole June 10th 2015, 12:58 pm
tconnection wrote:What oe parts that's in a glide need to be up graded to handle a 1000hp?
Planetary, input shaft, dual ring servo and clutch hub. Other parts are nice, but not 100 % required. Servo spring, new pump gears, etc.
Post  tconnection June 12th 2015, 11:10 pm
Ok thanks.
tconnection
Post  richter69 June 12th 2015, 11:27 pm
kevlar band (std width), stock drum w 8 frictions, deep pan, hardned band adj pin, aftermarket stator pump half .......
add this to Davids list you should be good.
Ill have a nice bte ringless input for sale soon, and may know where a Bte pump half is w a pinned stator tube.
Post  tconnection June 15th 2015, 12:07 am
Ok let me know. If I knew exactly what to buy as well as understood what to buy, I'ld go ahead and buy it but I dont know so i gotta do or might I say I'm doing some research to try to understand what's what.
plus, what the pro's and cons for the power glide and the c6?
tconnection
