Cleaning billet carb parts
nuclearcobra
What is safe to soak the billet metering blocks in ? , don't want to eat the finish off them soaking them in the chem dip like I would a regular carb.
nuclearcobra- BBF CONTRIBUTOR
Re: Cleaning billet carb parts
Spray carb cleaner and a blow gun?
dfree383 wrote:Spray carb cleaner and a blow gun?
X2 that how I clean my APD metering blocks then I spray them down with wd 40 and blow them off good it helps to keep the tarnish down and them looking shiny
Thanks guys that's what I'll do , I had a call into AED also and same reply , he said they use 2+2 and a air gun unless it's a real gunked up carb then it gets thrown in a heated sonic cleaner.
Electrical contact cleaner is good to 'blow out' mettering block passages and air bleeds.
Electro-Wash here.
68formalGT- Posts : 865
same stuff you use on the mass airflow metter......
» Cleaning out some parts
» 4160 Carb Rebuild/Cleaning Questions
» Demon Carb parts???
» Billet Parts
» Cleaning Out Ford Parts In Garage Immediatly In Houston Texas Area
» Billet Parts
