Blown Ford Hemi
crittersf1
jsracing
Blown Ford Hemi
4.125 Stroke X 4.5 Bore NHRA legal for Pro Mod class set up for Blown Alky.
see info below
see info below
Re: Blown Ford Hemi
C & C motor sports Alum block ( solid no water )
ALL parts were speced by Carol Carter @ C and C motorsports I can answer questions and of course Carol knows every detail about this motor also. feel free to call him too.
Billet Velasco Crank, CNC ported C and C motorsport HEMI heads - solid
Gear drive assembly, mag drive Jesel shaft rockers, Manton PRds, 3 stage dry sump, front engine drive
Arias custom pistons 11.7.1 ( 2 extra pistons ) Nick Arias/ Carol Carter speced.
MGP alum rods 2 extra rods
Blower Intake C and C motorsports, billet Intake spacers,
Crank support, dry sump pan, block bell pattern for Big ford or Mopar, Deg ring w magnets, Boss alum valve covers w blow down tubes, burst panel fuel pump drive. C and C motorsports Cam
I have ALL receipts and part numbers.
Motor is 100% NHRA legal and set up for blown alcohol.
This engine has NO provisions for water. Completely balanced, fully blueprinted.
I can fax the parts list from C and C. only items purchased separate were pushrods, rods, and they were per C and C specs.
$24K
No blower, No mag. I can throw in a nice set of zoomies if they fit your needs.
317 927 5890
Re: Blown Ford Hemi
See Below
Re: Blown Ford Hemi
See Below
Re: Blown Ford Hemi
jsracing wrote:I hate it. Love nostalgia of a blower the sound of zoomies etc. but the fact is turbos can make more power since they don't require crank power to turn them.
another reason is NHRA rules have a lot of restrictions on blown cars.
JS
NHRA = No Hot Rods Allowed
the Coug- Posts : 3055
Re: Blown Ford Hemi
Twins may be the ticket in 1/4 mile but the screws were putting it to 'em this past weekend at S.G.M.P.
Stevie Fast won Radial vs World with a BAE screw setup. Killer. 4.0x@ 195. The twins will never match the roots/screw factor in looks and sound. Stick with 1/8 mile if you can and let 'em try and catch you by the 660'.
738drvr- Posts : 600
Re: Blown Ford Hemi
RaiderBC wrote:Engine still for sale?
yes it is.
I might separate the heads/ intake/ short block.
Re: Blown Ford Hemi
$24K
Engine and Zoomies, no blower or hat.
Re: Blown Ford Hemi
I had talked to you on the phone about it a while back, so did the boat guy ever get the top end?
supervel45- Posts : 4499
» Blown Hemi
» delete
» Ford's Hemi "The Original Hemi"
» 815 Ford Hemi
» Bench Racing: Highest horsepower N/A 10.3" deck engine combo's
» delete
» 815 Ford Hemi
