80's crown vic rear suspension
I am looking into buying a 87 crown vic, it will eventually receive a mild 520ish engine. It will see only limited TNT time at open track nights. I would assume building stronger and adjustable controls arms will be necessary with the possibility of a coil over setup also. Should I also plan on multiple mounting holes off the chassis for more tuneability? Any info or suggestions would be appreciated. Thanks.
mudranger- Posts : 17
Re: 80's crown vic rear suspension
I'd box the stock stuff and add some good bushing. And see how it does.
That makes sence, I have a tendancy to over think things and make more work were it is not needed. Thanks
» Crown vic suspension and BBF Motor Mounts
» can a 1993 Crown Vic 8.8 rear work in a 1992 ford mustang?
» rear suspension (AKA baselinesuspensions )
» rear suspension
» fox body rear suspension
» rear suspension
