Heading to the dyno
+18
nitrous.f
Wheelie58
Mustang-junky
466cj
dirt_worker
bbfstanger
whitefield
68galaxie
butterbean
kim
fe50stang
22 posters
Page 2 of 2 Previous  1, 2
Heading to the dyno - Page 2 Empty Re: Heading to the dyno
Post  bbf-falcon November 9th 2014, 7:23 am
Comp lifters scare me w/big springs and heavy loads. Mine are coming out for sure now,this is happening way too often . Twisted Evil
Post  fe50stang November 9th 2014, 11:31 am
[quote="bbf-falcon"]Comp lifters scare me w/big springs and heavy loads. Mine are coming out for sure now,this is happening way too often . Twisted Evil [/
It looks like the roller bearing just stopped rolling. Everything was cleaned very well with brake cleaner when they came out of the box and the lifters soaked in oil for 5 days before assembly .
fe50stang
fe50stang
Post  bbf-falcon November 9th 2014, 11:36 am
Yea,it's happening a lot it seems. Mine are new,but they are coming out for sure,it's not worth losing good parts because of a weak part that can be avoided. I hate that for you. Sad
Post  bbfstanger November 9th 2014, 12:44 pm
that just sucks! was looking forward to seeing your results.
bbfstanger
Post  kim November 9th 2014, 1:02 pm
agree if it weren't for bad luck... ide have no luck at all.
kim
Post  dirt_worker November 9th 2014, 1:04 pm
Man that's a total bummer!!
I sleep MUCH better knowing my engine no longer has needle bearing lifters in it Shocked
Real sorry to hear about your misfortune Sad
dirt_worker
dirt_worker
Post  466cj November 9th 2014, 4:44 pm
Sorry to hear. I hope the damage not too bad and can get it back together soon. I agree like the bushed lifters better. I hear all the cautionary tails from the Moral camp, but have heard a lot of good luck from guys that have used the Isky EZ rollers for a good number of years now. For an engine like yours IMO be a good investment.
466cj
Post  fe50stang November 9th 2014, 5:27 pm
[url=Heading to the dyno - Page 2 Th_trim.5F982363-A3CE-435E-A6DD-E3D675C84C93_zpsgqjk2mrv]Heading to the dyno - Page 2 Th_trim.5F982363-A3CE-435E-A6DD-E3D675C84C93_zpsgqjk2mrv[/url]
A short clip of it running
fe50stang
fe50stang
Post  kim November 9th 2014, 6:08 pm
Wont let me open the link, says its been renamed or moved by owner.
kim
Post  FalconEh November 9th 2014, 7:19 pm
I Never like to hear this, hopefully minimal damage and the reassembly will net you more than you were expecting on the next dyno pull. Sad
Post  Mustang-junky November 9th 2014, 10:23 pm
I plan on firing up my 545 on tuesday for the first time. It has new Comp roller lifters in it too. affraid Something else to worry about now.
I hope your damage was minimal.
Jess
Mustang-junky
Mustang-junky
Post  Wheelie58 November 9th 2014, 10:32 pm
Sorry to hear of the failure. Our thoughts are with you.
Keith
Wheelie58
Wheelie58
Post  windsor November 10th 2014, 10:05 am
This is uber lame to hear...sorry.
How was the lash when you checked it after warm up? Did everything seem normal?
Post  fe50stang November 10th 2014, 10:16 pm
windsor wrote:This is uber lame to hear...sorry.
Everything seemed fine at the time. The only thing I can think of is maybe the tie bar hole was not drilled exactly center. It ground a flat spot in the roller before the lifter broke. But what's weird is nothing shows signs of heat. Not even the lifter. That broke. the pushrod looks brand also. I would think that if my lash was way off I'd hear it or at least see a little excessive wear on the pushrod tip?
fe50stang
fe50stang
Post  68galaxie November 11th 2014, 8:51 pm
Post some pictures when you do the tear down.
Others may have insight into the issues when pics are posted.
I am sure you will get it sorted.
68galaxie
68galaxie
Post  nitrous.f November 11th 2014, 9:04 pm
what p# were the roller lifters? Shocked
nitrous.f
nitrous.f
Post  rmcomprandy November 11th 2014, 11:53 pm
fe50stang wrote:
bbf-falcon wrote:Comp lifters scare me w/big springs and heavy loads. Mine are coming out for sure now,this is happening way too often . Twisted Evil [/
You did that OK ... DO NOT use Non-Chlorinated Brake Clean, any type chlorinated solvent, toluene. acetone or keytone cleaners on any internal engine parts unless you soak them immediately at least a full day in oil before assembly; no matter what the brand.
Post  DaveMcLain November 12th 2014, 9:57 am
On a new set of roller lifters I spend a LOT of time getting the assembly grease cleaned out of the roller bearings. I use mineral spirits in a can, soak them for a while, blow them out with an air hose and repeat over and over until no more grease comes out. Then I soak them in 10W-30 oil for an hour or so before putting them in the engine. Grease tends to not melt and or blend into the oil but instead it can stay inside of the roller and keep oil from getting to the bearing. I think that this can cause damage to the lifter and cause it to eventually fail. Maybe something like this happened.
DaveMcLain
Post  IDT-572 November 12th 2014, 11:25 am
DaveMcLain wrote:On a new set of roller lifters I spend a LOT of time getting the assembly grease cleaned out of the roller bearings.  I use mineral spirits in a can, soak them for a while, blow them out with an air hose and repeat over and over until no more grease comes out.  Then I soak them in 10W-30 oil for an hour or so before putting them in the engine.  Grease tends to not melt and or blend into the oil but instead it can stay inside of the roller and keep oil from getting to the bearing.  I think that this can cause damage to the lifter and cause it to eventually fail.  Maybe something like this happened.
This is my method also.............. So far so good. I have the 836-16 lifters in most of the engines I do. I have some with the Isky and Morels in them.
I have yet to have a failure.
I have had one go through valve float and pull them to check and they were spread at the axle. This was for one pass with a new cam.
I dressed the sides and replaced the springs reassembled and it is still running.
Post  BOSS 429 November 12th 2014, 11:50 pm
how long did you prime the engine with a drill on the dyno before you started it for the first time? and what was the oil presser?
Post  514Fox87 November 13th 2014, 8:30 pm
I had the same thing happen when I build my engine with the custom cam and comp. lifters. Sent them back to comp. and they said the tie bar is what broke. Happy to say they sent me a new cam and replaced the lifters and tie bar for no charge. Been in 2 years now but are going to be replaced this winter. Sorry to hear about the bad luck.
514Fox87
514Fox87
