SV 1 Carbs
+8
514Fox87
AZFairlane
dr's wife racing
12 posters
SV 1 Carbs Empty SV 1 Carbs
Post  dr's wife racing November 5th 2014, 12:55 pm
Any one on here had any dealings with them?
dr's wife racing
dr's wife racing
SV 1 Carbs Empty Re: SV 1 Carbs
Post  rmcomprandy November 5th 2014, 3:06 pm
dr's wife racing wrote:Any one on here had any dealings with them?
I have run a couple customers carb/engines on the dyno and it never impressed me enough to buy one or recommend buying one.
Post  richter69 November 5th 2014, 4:50 pm
Every combo ive seen w one had issues, but im sure they work fine for some folkes. i think Barney has one and likes it.
Post  dfree383 November 5th 2014, 5:02 pm
couple I've see where either Heros or Zeros, not much in between.
Post  BOSS 429 November 5th 2014, 5:11 pm
If your engine makes less then 700ish hp. then a sv1 isn't really for you. I just received another one yesterday to dyno with.
I like them, And have another one on the way.
Post  dr's wife racing November 5th 2014, 7:51 pm
Motor is a 605ci A head.made a little over a thousand with a nos cam.
dr's wife racing
dr's wife racing
Post  bbf-falcon November 5th 2014, 8:19 pm
When you get them fine tuned they are as tame as a street carb. Throttle response is a lot like injection. Patrick is very helpful and knowledgeable.
Post  AZFairlane November 5th 2014, 8:34 pm
You may not be able to get a lot of help from Patrick, he was in a car wreck and is busted up pretty good, long recovery.
AZFairlane
AZFairlane
Post  514Fox87 November 5th 2014, 8:38 pm
I run one on my 466 A429 head motor. The bad is they are finicky. The good is when you get them right they are bad to the bone. Patrick converted mine from gas to alcohol and sent me the blocks etc. so I can change it back to gas. Basically I have 2 carbs. in one. I have found that it is about 2 1/2 mph faster then anyone else running same et as I am. The tech line is very helpful and Patrick if he doesn't answer always calls back. I haven't gotten mine tuned 100% but it is close. Bad thing is Patrick was in a bad accident over the weekend and was pinned by his legs for 40 minutes and is in hospital with multiple broken bones. Legs, ankles, feet etc. Not sure who is running everything now.
That said I have a friend at the track that runs one and loves it. Has only had to change air bleeds to make it work and speaks highly of the carb.
514Fox87
514Fox87
Post  bbf-falcon November 5th 2014, 8:51 pm
[quote="514Fox87"]I run one on my 466 A429 head motor.  The bad is they are finicky.  The good is when you get them right they are bad to the bone.  Patrick converted mine from gas to alcohol and sent me the blocks etc. so I can change it back to gas.  Basically I have 2 carbs. in one.
I agree completely. I also switched mine from Alc. back to gas. Easy conversion. Very Happy
Post  Wes Littrell November 6th 2014, 8:16 am
I've got one on my 572. Like it a lot. Great idle. Runs great. Mine was a used one that came off a tunnel ram pro stock engine. They used it for testing and said it made more power than any of their dominators. They campaigned to get NHRA to allow them but couldn't get it done. Sold 2 matched sets. I didn't do anything to mine and it runs great. I'm sure I could send it back and get a better calibration and it be even better.
Wes Littrell
Wes Littrell
Post  BOSS 429 November 6th 2014, 8:39 am
the one I had on a little engine 472 didn't make much more power, about 8hp more then the 4v that was on it,but picked up 22tq . engine made 600hp with 4v so we just left it.
they work good,and really good if you have an engine that can move some air.
Post  dr's wife racing November 6th 2014, 11:09 am
I ended up buying it. Got a sweet deal on it. It was on a good friends BBC 590 ci some type dart heads. It ran 5.00's but turned into a million tiny pieces when the crank broke. His combo was very similar to mine even very close dyno ## it was a great tune up for his I plan on puttin it on my victor and running it with a foggèr. I will keep the 2x4 on alky with plate system.
dr's wife racing
dr's wife racing
Post  Barney November 6th 2014, 11:25 am
Switching from duals to a single sv1 on a 600 inch a headed deal. I'll pm you and let you know.
Barney
Barney
Post  kim November 6th 2014, 12:18 pm
Barney wrote:Switching from duals to a single sv1 on a 600 inch a headed deal. I'll pm you and let you know.
Did you go with one of the LARGE SV1? I was on Patrick's web sight and saw the thing can go to 2600CFM on a single SV1. Now that's pretty damn impressive. Half the fuel lines, rid of the linkage concerns, wonder about distribution of a single feed on a tunnel ram base???
kim
Post  dr's wife racing November 6th 2014, 7:04 pm
Let me know how it works for you Barney.
dr's wife racing
dr's wife racing
Post  Barney November 6th 2014, 8:50 pm
yes it's large.
Barney
Barney
Post  valleydawg November 8th 2014, 9:04 am
I have one on both of my engines. I really like them.
valleydawg
valleydawg
