fox swap mounts
fox swap mounts Empty fox swap mounts
Post  tiger November 16th 2009, 3:32 pm
When you buy the motor mounts for the fox swap, what did the rubber mounts that bolt to the frame come off of?
tiger
fox swap mounts Empty Re: fox swap mounts
Post  Mark Miller November 17th 2009, 1:40 am
I'm pretty sure they were from Ford Trucks with a FE engine,somebody posted those part numbers here or on the 460ford site recently.
Later Mark.
Post  Mark Miller November 17th 2009, 3:09 am
I'm pretty sure i found them on the Autozone Website Duralast Part Number 2289 For Passenger Side and 2290 For Drivers Side.I looked up a 70 F-250 with a 390 FE Engine.
Later Mark.
Post  Mark Miller November 17th 2009, 3:14 am
Looks like the Duralast ones are only $6.99 a piece hopefully you car find them at a Autozone locally to you.
Later Mark.
Post  tiger November 17th 2009, 9:53 am
Thank you very much.
tiger
Post  Mark Miller November 18th 2009, 1:09 am
No Problem.
Later Mark.
Post  jbozzelle November 27th 2009, 2:28 pm
I have these numbers off of the swap mounts I have.
2290, must be an Autozone number or similar. Not a factory piece.
C7TA-6BO(or maybe a 0)32-J
Both driver and passenger look to be the same.
Post  ustahava67 November 30th 2009, 1:41 am
Yep, 390 truck pads and they are the same on both sides. I worked at Kaufmann Products back in the early 80's. Back then I think we were the first ones to swap a 385 engine into a fox chassis. We used the Station Wagon motor plates with the truck mount and a 3/4 alum biscuit to get K-member clearance
ustahava67
ustahava67
Post  tiger December 4th 2009, 4:37 pm
This was a big help, I just went and bought the mounts. Thanks guys.
tiger
Post  Mark Miller December 5th 2009, 2:00 am
No Problem,any other questions you might have ask away i'll try to help.
Later Mark.
