Carb and Intake question
Carb and Intake question Empty Carb and Intake question
Post  94MustangBBF November 13th 2014, 11:27 pm
94 Mustang drag car, approx 3200 lbs right now motor is stock bottom, flat tops, FRPP C460 cam, eddy rpm 95cc heads, 9.66:1 compression, eddy rpm intake and demon 850 carb. Im wanting to upgrade carb and intake this winter. I was thinking a tfs victor intake and 1050 dominator gas carb, was told that was a bit much and i need a 4150 carb because the booster signal would be weak with a dominator. Im only wanting to go bigger, and better engine from here, I dont want to upgrade the motor via more compression, cam, better cylinder head and have to get another intake and carb because they are too small. What do you all think? Im lookin at 2 choices possibly, 1050 dominator gas carb and tfs intake, or tfs 4150 style intake and a AED 950 hp carb.
1 more question i have is that current trans is stock c6 with boss hog 3500 converter, trans needs gone through this winter, manual valve body and rebuild, should i keep the converter thats in it? i Do have access to a 4500 converter, I beleive 9" converter.
Thanks for your time, Travis
94MustangBBF
Carb and Intake question Empty Re: Carb and Intake question
Post  94MustangBBF November 13th 2014, 11:36 pm
If it helps, this motor made 519@5900 on dyno and 550 lb/ft cant remember what rpm, have to get back on that.
94MustangBBF
Carb and Intake question Empty carb
Post  butterbean November 14th 2014, 12:39 pm
I would go to a Dominator "1050" and a Victor 460 for that 4500 flange carb. and I would go to a race type converter weather it is a 9" or a 8" with your manual valve body, the intake and carb will get you 20-30 more HP, the way to look at it would be remember back in the old days when everybody put a tunnel ram and 2 600 holleys on there race cars? its kinda the same thing but in one carb if that makes sense???? good luck in what ever you choose to do and have fun with it.
butterbean
butterbean
Post  rmcomprandy November 14th 2014, 2:57 pm
butterbean wrote:I would go to a Dominator "1050" and a Victor 460 for that 4500 flange carb.
Good recommendation ... have the head intake ports "Victor" port matched; (the manifold ports are on CJ centers but, smaller than CJ size).
Post  crittersf1 November 14th 2014, 5:33 pm
I agree with the dominator carb and the victor intake.
crittersf1
crittersf1
Post  94MustangBBF November 16th 2014, 5:16 pm
Victor and dominator it is, thank you guys for the replies.
94MustangBBF
Post  94MustangBBF November 24th 2014, 3:26 am
Soon as the holidays are over ill be ready to start ordering parts. What carb would be best? Im lookin between the holley 8896-1 or quick fuel qfx carb. What do you guys think qould be best for my application?
Travis
94MustangBBF
Post  dfree383 November 24th 2014, 9:34 am
Hard to beat the QFX for features.
The Holley Ultra series are good too.
Post  butterbean November 24th 2014, 12:38 pm
I know the Quick fuel carbs are new and improved but I've always used the Holley HP series and the 8896 3 circuit carb and always have had great results with them, my E-85 Dommy is a 8896-2
butterbean
butterbean
