REED roller cam for 385
REED roller cam for 385 Empty REED roller cam for 385
Post  rmcomprandy November 15th 2014, 6:32 pm
Take out REED roller cam, trade-in - NEVER run but, installed  in a ready to run engine which a customer bought somewhere else and had me go through it.
This cam has only a 3/8" threaded hole for attaching the timing gear.  Customer didn't want it modified for a larger bolt but, it still should be enlarged.  He simply ordered a "custom" grind camshaft instead.
This was installed in a "Truck Puller" engine - 521", 11.8/1 compression, Blue Thunder heads with Chevy exhaust flange, single model 4150 carb as per those class rules.
Cam specs:
REED ROLLER #XL- 320-24R -8A3
320/324@lash
282/286@.050"
.435"/.435" Lobe lift
108 separation + 3 @105 intake centerline.
First $250.00 + shipping takes it.
REED roller cam for 385 Empty Re: REED roller cam for 385
Post  rmcomprandy December 5th 2014, 1:23 am
ttt
Post  rmcomprandy December 22nd 2014, 5:06 pm
You mean to tell me than NOBODY is looking for an inexpensive, serious roller camshaft for a 4 barrel NA pulling or mud application...?
Post  rmcomprandy January 19th 2015, 5:27 pm
ttt
Post  rmcomprandy March 14th 2015, 10:59 am
rmcomprandy wrote:You mean to tell me than NOBODY is looking for an inexpensive, serious roller camshaft for a 4 barrel NA pulling or mud application...?
again...
REED roller cam for 385 Empty cam
Post  78PULLER March 17th 2015, 9:33 pm
pm sent
78PULLER
