514 Dyno guesstimate
+9
Tore
bigblok2000ranger
gmsmkr
butterbean
Mark Laczo
13 posters
last winter I built a 514 short block for one of my best friends and Forum member.I won't mention his name because I didn't ask his permission too post.he might chime in,not sure.
Anyway,it was a 4.14 crank,6.8 rod,4.440 bore deal w/p51 Scj valve angle pistons.Some of the spec's I will guess at because I sent his Cam card and other info back w/engine. He had a set of p51 heads w/2.300 1.76 stainless valves. Sent them too one of the best head guy's around and had the porting and vj done.They averaged 438 int. at 750 and 440 at 800. and 265 on the ext. side. I'm thinking the cam lift was in the 768 range w/seems like 112 lsa. 15.1 comp.Could stand a lot more Cam imo. Mafia intake also ported by same guy. The biggest carb he had was 1250 w/99 jets and it wanted more he said but that as big as he had. What HP do you guy's think it made on the Dyno @ 7000. I haven't seen the sheet,as he didn't have it w/him when he called me tonight.
514 dyno
Without knowing .050" numbers I would say somewhere north of 900ish ??
That's really good flow on those P51's about 15-20 more than some others.
Mark Laczo- Posts : 274
Re: 514 Dyno guesstimate
Duration @.050 int.270 exh. 280
110 centerline
Lift .785int. .760ext.
110 centerline
825-850 is my guess
The reason the cam is so small is it was speced a few years back when the heads were stock.it will def pickup w/new cam speced for the new head flow. Dave, my guess was close to yours just before it went to dyno.My guess was 870 and the owner said he would be happy with 850.
bbf-falcon wrote:The reason the cam is so small is it was speced a few years back when the heads were stock.it will def pickup w/new cam speced for the new head flow. Dave, my guess was close to yours just before it went to dyno.My guess was 870 and the owner said he would be happy with 850.
With a 514, unless it has titanium intake valves and can easily rev higher, a bigger cam won't add much horsepower at all. Maybe 10 or so but. it would lose at least twice as much torque.
Thx Randy, that's why I leave the cam design to the pro's.
well???? what did it make????
butterbean- Posts : 676
It made 866@7000 and 700ft lbs torque.
DAMN, I need that combo in my T-Bird, it would make 1 fast bracket car with big MPH!!! hell I'm hoping for 700 wimpy azz HP
Last edited by butterbean on November 27th 2014, 12:32 pm; edited 1 time in total (Reason for editing : added)
Owner sent me the dyno sheet and head flow sheet, if I can figure out how to post them from this tablet.
bbf-falcon wrote:Owner sent me the dyno sheet and head flow sheet, if I can figure out how to post them from this tablet.
we will be waiting
Guesetimate hell you guys had the coconut calculators running dyno passes spot on
FalconEh- Posts : 1448
I think I could live with a combo like that
gmsmkr- Posts : 1364
bbf-falcon wrote:Duration @.050 int.270 exh. 280
110 centerline
rmcomprandy wrote:bbf-falcon wrote:The reason the cam is so small is it was speced a few years back when the heads were stock.it will def pickup w/new cam speced for the new head flow. Dave, my guess was close to yours just before it went to dyno.My guess was 870 and the owner said he would be happy with 850.
With the flow numbers posted would it not have more power with cam specs similar to 270*@.050" .785"/285*@.050" .800" lift?
I sent the results to Rick and he can't post them and I don't know how. If I send the dyno sheet out can someone post it up?
Thanks Tore
Thanks Tore
Tore- Posts : 865
bbf-falcon wrote:It made 866@7000 and 700ft lbs torque.
Rick,nice job if it ran on 93 octane pump gas that would be a nice engine for my Mustang.
Mark Miller- Posts : 1959
If you don't have a scanner just take a picture of the sheet and post it like any other picture.
jasonf- BBF CONTRIBUTOR
Good to hear. I have the same shortblock with out the box P51s and mafia intake... looks like I have some good stuff to grow into...
jbozzelle- Posts : 3705
» dyno next week any hp guess's ///rod picture damage and dyno sheet added
» Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
» guesstimate on horse power
» Budget 466 build, hp guesstimate.
» New bullet 1003 hp 810 tq P51
