Best cam for a 4x4 bronco?
Best cam for a 4x4 bronco? Empty Best cam for a 4x4 bronco?
Post  BleedinBlue77 December 16th 2014, 8:35 pm
Hey guys I am building a bronco to go four wheeling. Its getting a 460 but I am not sure what cam to go with. Do you guys have any wisdom that will help me pick a cam?
BleedinBlue77
Best cam for a 4x4 bronco? Empty Re: Best cam for a 4x4 bronco?
Post  dfree383 December 16th 2014, 8:51 pm
Need a lot more info.... What's the engine? Heads? Compression? Exhaust? Trans? Convertor? Tires? gearing? Is it for racing or just trail riding?
Post  BleedinBlue77 December 16th 2014, 10:38 pm
Sorry haha. I have a block out of 83 f-250 with the original heads. I am going to do a mild port job, chambers polished and port match with a 750 holley carb. With roller rockers with 1:73 ratio. It will have 9.5:1 compression. A performer rpm dual plane intake. C6 tranny. 38s for tires. 4:10 gears. straight pipe exhaust. Mostly trail but will hit some nasty Boggs. Not sure what the best cam for this would be
BleedinBlue77
Post  dfree383 December 16th 2014, 11:00 pm
Something in the comp cams extreme or Lunati voodoo line would work good.
220-225 degrees at .050 on the intake and about 10 more degrees at .050 on the exhaust. Lift will be in the mid .500s
Stick with a hydraulic it's low maintence and inexpensive.
Either on of these would work well
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=998&sb=2
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=997&sb=2
Post  BleedinBlue77 December 16th 2014, 11:58 pm
Yea I like those cams! Thanks for the help!
BleedinBlue77
Post  DanH December 17th 2014, 12:20 am
BleedinBlue77 wrote:Hey guys I am building a bronco to go four wheeling. Its getting a 460 but I am not sure what cam to go with. Do you guys have any wisdom that will help me pick a cam?
your other thread said you Already have the cam. What up?
DanH
Post  BleedinBlue77 December 17th 2014, 12:33 am
No I was just wondering if I used that cam what would the output be. Haha. I don't have a cam yet still on the hunt. Its hard to be patient though haha.
BleedinBlue77
