Direct port or Sledgehammer
gmsmkr
Thinking about putting nitrous on and need to know the pros and cons of each. If anyone has used both your input would be appreciated.
Thanks in advance,
John
Thanks in advance,
John
John Myrick- BBF CONTRIBUTOR
Re: Direct port or Sledgehammer
With direct port you can fine tune each cylinder with a plate it is what it is. The plate will give a harder hit do to it being up higher at the carb pad.
gmsmkr- Posts : 1364
A plate is easy.
Port injection is always favored.
Curt- Posts : 2791
i used both, direct port ftw.....
One of the things I always ask a potential customer is how much MAX HP might you EVER be looking for. Sometimes room for growth is impotant, and sometimes if a guys only looking for say a max of 2-300 a plate is easier for many.. Thanks, SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
ihave used both had 2 foggers on a small block and a big block with a fogger and a plate, The new sledge hammer is very nice for spraying the house down over 40 pills 400hp you can not beat an annular fogger, but under that the plate rules
studly- Posts : 512
With a plate set up how much better would distribution be with a 4500 mafia intake versus a 4500 victor? I know the TFS intake is better overall, just wondering if it would be more nitrous friendly also.
Thanks,
Sheldon G
Thanks,
Sheldon G
STR-LGL-70- Posts : 223
STR-LGL-70 wrote:With a plate set up how much better would distribution be with a 4500 mafia intake versus a 4500 victor? I know the TFS intake is better overall, just wondering if it would be more nitrous friendly also.
Thanks,
Sheldon G
The TFS intake is bigger, but not necessarily better on all applications.
I don't think either one would be any better than the other as far as distribution
» Direct Port Systems
» Induction Solutions direct port
» Fall deals on direct port systems..
» Square port intake vs oval port
» Plates & Direct Ports?
