Adding a baffle to a FRPP swap fox (truck) oil pan.
+7
butterbean
kim
11 posters
Adding a baffle to a FRPP swap fox (truck) oil pan. Empty Adding a baffle to a FRPP swap fox (truck) oil pan.
Post  BigBlockRanger January 27th 2015, 10:35 am
After seeing a thread on 460Ford, ( http://www.460ford.com/forum/showthread.php?t=182953 ) I decided to add a baffle to my stock truck pan. I have never had a problem with losing oil pressure at launch or in the shut down area, but I figured it would be nice to keep the oil from climbing up the back of the pan at launch.
I started on mine yesterday. I cut a piece of cardboard that fit snugly in the pan. Then I put the oil pump and pickup on the motor. I dobbed oil on the bottom of the pickup and lowered the pan over the block. This left an oil circle on the cardboard.
Adding a baffle to a FRPP swap fox (truck) oil pan. 10940507_10153057447154485_2733603885180033973_n
I cut out the circle, then repeated the process by dobbing oil on the pickup tube until I had the appropriate notch made in the baffle.
Adding a baffle to a FRPP swap fox (truck) oil pan. 10606234_10153057447124485_5763187697436748682_n
Today or tomorrow, I will buy a small piece of sheetmetal, cut out the hole and weld it in the pan. I will detail that process in a later post.
Adding a baffle to a FRPP swap fox (truck) oil pan. Empty Re: Adding a baffle to a FRPP swap fox (truck) oil pan.
Post  69F100 January 27th 2015, 12:20 pm
I will be watching I need to add one to my pan also I haven't lost oil pressure on launch or shut down ether but will be good for added insurance. Now I have the front end changed over to strut I can drop my pan with out pulling the engine was going to buy a new pan but might just do what you are doing instead.
Post  dfree383 January 27th 2015, 12:33 pm
Extend the sides an bend the up. Drill holes in the flaps an plug weld the to the pan.
Post  BigBlockRanger January 28th 2015, 10:44 am
I was actually going to check around to see if any of my friends have a spot welder, but the plug weld option might be just as good.
Post  kim January 28th 2015, 11:10 am
raise it as high as possible, Cant have crank hitting it, then trap door with small spring, the front to back drain. Let the oil flow in, but don't let it slosh forward out. With a solid sheet as pictured, might run into issue with oil having hard time returning to sump.
kim
Post  Curt January 28th 2015, 11:17 am
BigBlockRanger wrote:I was actually going to check around to see if any of my friends have a spot welder, but the plug weld option might be just as good.
You should really tig weld it. To much heat and you'll have cracks everywhere.
Post  BigBlockRanger January 28th 2015, 2:31 pm
I am following Randy's advice as to how it is constructed.
The baffle should be curved slightly from front to rear with the low spot near the center at the pick-up access hole.
Stitch weld the baffle in the front and the back with the gap from the baffle to the pan no MORE than .040". The sides can be about .125" gap.
Post  rmcomprandy January 28th 2015, 4:23 pm
BigBlockRanger wrote:After seeing a thread on 460Ford, ( http://www.460ford.com/forum/showthread.php?t=182953 ) I decided to add a baffle to my stock truck pan.  I have never had a problem with losing oil pressure at launch or in the shut down area, but I figured it would be nice to keep the oil from climbing up the back of the pan at launch.
For THAT pan ... that flat baffle will work fine. Simply stitch weld it in a few places.
Post  butterbean January 28th 2015, 7:31 pm
I done my pan as well and it turned out fine, I used a body panel mig welder on med heat and its good,
butterbean
butterbean
Post  BigBlockRanger January 29th 2015, 2:54 pm
Worked on the baffle a little at lunch yesterday.
Adding a baffle to a FRPP swap fox (truck) oil pan. 10828039_10153063046284485_7503284946270160398_o
I decided to bend the sides up to make it easier to weld. I have since changed my mind and will only have some tabs on the sides to weld to.
Adding a baffle to a FRPP swap fox (truck) oil pan. 10426749_10153063046289485_2729327375556875718_n
So far.
Adding a baffle to a FRPP swap fox (truck) oil pan. 10686686_10153063046279485_6816714733176889031_n
I have plenty of metal to make a version 2.0 should I really jack this one up. Smile
I didn't have a lot of time to fiddle today, but I did have a chance to fill the pan with water to see where the oil level is.
The setup.
Adding a baffle to a FRPP swap fox (truck) oil pan. 10450830_10153065246289485_1324900090562136300_n
3 quarts
Adding a baffle to a FRPP swap fox (truck) oil pan. 10947448_10153065246224485_4474769475477937487_o
4 quarts - this is the level I was most interested in. I figure this would likely be similar to the nominal level when the engine is running.
Adding a baffle to a FRPP swap fox (truck) oil pan. 10947171_10153065246034485_8488161921102744726_n
5 quarts
Adding a baffle to a FRPP swap fox (truck) oil pan. 10945034_10153065246014485_4218698917639180729_n
6 quarts
Adding a baffle to a FRPP swap fox (truck) oil pan. 10297786_10153065246009485_8853950367644247996_n
It's a lot closer to the dipstick tube than I imagined.
Adding a baffle to a FRPP swap fox (truck) oil pan. 10947306_10153065245919485_2949732072150108615_n
Even though the baffle will be submerged, I still think I will make it slope a bit towards the hole.
Post  BigBlockRanger January 30th 2015, 9:37 am
I had a little time last night to work on this.
I cut out the hole, flanged it and added a bend near the centerline of the hole to make it match the contour of the pan better. The notch for the pickup tube looks a little wonky, but I don't care. I just need to test fit it again and if it is ok, weld it in.
Adding a baffle to a FRPP swap fox (truck) oil pan. 1625463_10153066950994485_432582101290769792_n
Post  the Coug January 30th 2015, 10:42 am
James personally I would just build a windage tray and make it fit with the pan  it is more important than a pan baffle it will also keep the crank from pickup the oil if it is above the baffle...
Post  richter69 January 30th 2015, 8:53 pm
I shoulda took some pics of the pan I got from Lem for this 580, pretty cheap, clears a kasse pump, baffled and a built in windage tray and scraper, powdercoated inside and out, will clear main caps on a A460 block ..... no brainer imo.
Post  Lem Evans January 30th 2015, 9:16 pm
Yes you should have Evil or Very Mad
Post  richter69 January 31st 2015, 12:05 am
the bigger ID pickup tube is a plus also. Tube needed a little tweak but nothing major.
Post  Lem Evans January 31st 2015, 11:38 am
richter69 wrote:I shoulda took some pics of the pan I got from Lem for this 580, pretty cheap, clears a kasse pump, baffled and a built in windage tray and scraper, powdercoated inside and out, will clear main caps on a A460 block ..... no brainer imo.
Adding a baffle to a FRPP swap fox (truck) oil pan. M-6675-DRS460_zpsvxff9ud7
Post  Mike R January 31st 2015, 6:45 pm
Nice piece, how much?
