BBF Deck height
BBF Deck height
so why are so many guys worried about deck height ....... they want to have a 10.200 height or even some guys want a 10.000 height ......?? is there and advantage to doing that ??? just mill the heads right
Re: BBF Deck height
Some want the shorter deck height to reduce push rod length and help valve train stability. Plus if you have CID limits their is some times no need for the additional weight of the higher block also.
short deck block
Hey Bruno I know this is an old thread but havent posted in a while and well just wanted to post I have 2 new 9.75 deck blocks coming from california hopefully here in the next week I will post some pics when they get here but my reason for this is the 525 inch limit,valve train geometry for over 1"lift and 9500 to 9800 rpm engine, the piston design, rod length. to make a 525 with a 10.00 deck then make a 525 with a 9.75 deck same cubic inch motor i would rather have more bore then stroke with 3 stages or possibly 4 there is defenitely more room to play I know everyone has mixed feelings on builds like this but I just thought the short deck would be the route to go. When I get some parts setting here i will get some photos up. Happy new yrs everybody. Jeremy.A
jsaracing11- Posts : 6
Re: BBF Deck height
thxs for the info Jeremy
