Wing thickness
Wing thickness Empty Wing thickness
Post  HorsinAround February 6th 2015, 12:32 pm
Looking at making a wing for my truck project. What thickness of aluminum should I use?
http://www.frontpagefab.com
Wing thickness Empty Re: Wing thickness
Post  DILLIGASDAVE February 7th 2015, 7:03 am
Depending on how big you make it, and how/where you mount & support the wing, you can usually use something in the .040-.050" to .080" thick range for different parts of the wing. IMO it's usually a good idea to go a little thicker on the spill plates (& adjustable wickerbill if used) vs the deck part just so the spill plates don't bend as easily when someone walking by bumps into them, or gets their shirt or coat snagged on them.
Post  HorsinAround February 7th 2015, 4:20 pm
I plan to have an aluminum tonneau over the bed then the wing will extend 18" past the tailgate.
Post  gmsmkr February 8th 2015, 12:52 pm
Will it have struts or no struts?
gmsmkr
gmsmkr
Post  HorsinAround February 9th 2015, 11:27 am
Something like this is what I am considering.
Wing thickness Rear%20Wing_zpsgq2olcqc
Post  gmsmkr February 9th 2015, 8:00 pm
For us rednecks a 1/16 should fit the bill nice...the bends and side plates will help stiffen it up
gmsmkr
gmsmkr
Post  DILLIGASDAVE February 11th 2015, 3:20 am
HorsinAround wrote:Something like this is what I am considering.
IMO a wing with that much overhang past the end of the deck/bed needs to use some adjustable support struts/rods.
Post  HorsinAround February 11th 2015, 9:57 am
That could very well be the case, especially mounted on the tailgate where the panel metal isn't the thickest. I ordered the aluminum yesterday, so I will know more as it get it put together. I ordered enough material to include an adjustable wickerbill also. Now I just need to order the aluminum piano hinge and wickerbill adjusters.
Are screws normally used to put these together or are solid rivets used?
Post  gmsmkr February 11th 2015, 7:17 pm
Most use a small button head Allen screw with lock nuts
gmsmkr
gmsmkr
Post  HorsinAround March 7th 2015, 11:06 pm
Wing thickness 2015-03-06%2000.38.40_zpsr6byvy83
Here's what I came up with
Post  cool40 March 8th 2015, 2:16 am
Cool
Post  gmsmkr March 8th 2015, 10:36 am
cheers how about a pic from the back and side
gmsmkr
gmsmkr
